Bump connection_pool from 2.2.2 to 2.2.3 (PR #9967)
Bumps connection_pool from 2.2.2 to 2.2.3.
Changelog
Sourced from connection_pool's changelog.
2.2.3
  • Pool now throws ConnectionPool::TimeoutError on timeout. #130
  • Use monotonic clock present in all modern Rubies [Tero Tasanen, #109]
  • Remove code hacks necessary for JRuby 1.7
  • Expose wrapped pool from ConnectionPool::Wrapper [Thomas Lecavelier, #113]
Commits
  • 8b830d2 Rejigger to remove errors.rb
  • 35a8891 Integrate standard gem, code formatting fixes, no functional changes
  • f93e357 Move wrapper into separate file
  • dd5dac5 Rejigger exceptions, fixes #130
  • c46a347 CI: Use openjdk11
  • bd71bd4 CI: refer to JRuby using rvm alias
  • a8336b4 CI: Run latest JRuby release
  • 9c15ab6 README: Use API Redis.new in example
  • 8671abd Removed explicitly declaration of thread library.
  • 22592e2 Add ruby 2.7 to CI
  • Additional commits viewable in compare view
GitHub
