Bump lodash from 4.17.15 to 4.17.19 (PR #55)
Bumps lodash from 4.17.15 to 4.17.19.
Release notes
Sourced from lodash's releases.
4.17.16
Commits
Maintainer changes
This version was pushed to npm by mathias, a new releaser for lodash since your current version.
You can disable automated security fix PRs for this repo from the Security Alerts page.
GitHub
Superseded by #67.
