Bump rails_failover from `a878529` to `4225f7e` (PR #9976)
Bumps rails_failover from a878529 to 4225f7e.
Commits
GitHub
OK, I won’t notify you again about this release, but will get in touch when a new version is available.
If you change your mind, just re-open this PR and I’ll resolve any conflicts on it.
