Bump redis to 4.2.0.
index 2870d86..3aee171 100644
--- a/Gemfile.lock
+++ b/Gemfile.lock
@@ -310,7 +310,7 @@ GEM
       msgpack (>= 0.4.3)
       optimist (>= 3.0.0)
     rchardet (1.8.0)
-    redis (4.1.4)
+    redis (4.2.0)
     redis-namespace (1.7.0)
       redis (>= 3.0.4)
     regexp_parser (1.7.1)
diff --git a/config/initializers/002-rails_failover.rb b/config/initializers/002-rails_failover.rb
index 54692b7..2b84cf1 100644
--- a/config/initializers/002-rails_failover.rb
+++ b/config/initializers/002-rails_failover.rb
@@ -65,7 +65,7 @@ if ENV["ACTIVE_RECORD_RAILS_FAILOVER"]
   RailsFailover::ActiveRecord.register_force_reading_role_callback do
-    Discourse.redis.exists(
+    Discourse.redis.exists?(
       Discourse::PG_READONLY_MODE_KEY,
       Discourse::PG_FORCE_READONLY_MODE_KEY
diff --git a/lib/admin_confirmation.rb b/lib/admin_confirmation.rb
index dc132b7..28f305b 100644
--- a/lib/admin_confirmation.rb
+++ b/lib/admin_confirmation.rb
@@ -43,7 +43,7 @@ class AdminConfirmation
   def self.exists_for?(user_id)
-    Discourse.redis.exists "admin-confirmation:#{user_id}"
+    Discourse.redis.exists? "admin-confirmation:#{user_id}"
   def self.find_by_code(token)
diff --git a/lib/discourse.rb b/lib/discourse.rb
index 67ac64c..2706629 100644
--- a/lib/discourse.rb
+++ b/lib/discourse.rb
@@ -489,7 +489,7 @@ module Discourse
   def self.readonly_mode?(keys = READONLY_KEYS)
-    recently_readonly? || Discourse.redis.exists(*keys)
+    recently_readonly? || Discourse.redis.exists?(*keys)
   def self.pg_readonly_mode?
diff --git a/lib/discourse_redis.rb b/lib/discourse_redis.rb
index 096c86b..9ca18dc 100644
--- a/lib/discourse_redis.rb
+++ b/lib/discourse_redis.rb
@@ -193,7 +193,7 @@ class DiscourseRedis
   # Proxy key methods through, but prefix the keys with the namespace
-  [:append, :blpop, :brpop, :brpoplpush, :decr, :decrby, :expire, :expireat, :get, :getbit, :getrange, :getset,
+  [:append, :blpop, :brpop, :brpoplpush, :decr, :decrby, :expire, :expireat, :exists, :exists?, :get, :getbit, :getrange, :getset,
    :hdel, :hexists, :hget, :hgetall, :hincrby, :hincrbyfloat, :hkeys, :hlen, :hmget, :hmset, :hset, :hsetnx, :hvals, :incr,
    :incrby, :incrbyfloat, :lindex, :linsert, :llen, :lpop, :lpush, :lpushx, :lrange, :lrem, :lset, :ltrim,
    :mapped_hmset, :mapped_hmget, :mapped_mget, :mapped_mset, :mapped_msetnx, :move, :mset,
@@ -207,19 +207,6 @@ class DiscourseRedis
-  # Implement our own because https://github.com/redis/redis-rb/issues/698 has stalled
-  def exists(*keys)
-    keys.map! { |a| "#{namespace}:#{a}" }  if @namespace
-    DiscourseRedis.ignore_readonly do
-      @redis.synchronize do |client|
-        client.call([:exists, *keys]) do |value|
-          value > 0
-        end
-      end
-    end
-  end
   def mget(*args)
     args.map! { |a| "#{namespace}:#{a}" }  if @namespace
     DiscourseRedis.ignore_readonly { @redis.mget(*args) }
diff --git a/spec/components/discourse_redis_spec.rb b/spec/components/discourse_redis_spec.rb
index 8e44116..abc9a59 100644
--- a/spec/components/discourse_redis_spec.rb
+++ b/spec/components/discourse_redis_spec.rb
@@ -87,31 +87,6 @@ describe DiscourseRedis do
         expect(Discourse.recently_readonly?).to eq(true)
-    describe '.exists' do
-      it 'should return false when key is not present' do
-        expect(Discourse.redis.exists('test')).to eq(false)
-      end
-      it 'should return false when keys are not present' do
-        expect(Discourse.redis.exists('test', 'test2')).to eq(false)
-      end
-      it 'should return true when key is present' do
-        Discourse.redis.set('test', 1)
-        expect(Discourse.redis.exists('test')).to eq(true)
-      end
-      it 'should return true when any key is present' do
-        Discourse.redis.set('test2', 1)
-        expect(Discourse.redis.exists('test', 'test2')).to eq(true)
-        expect(Discourse.redis.exists('test2', 'test3')).to eq(true)
-      end
-    end
   context '.slave_host' do
GitHub sha: 98bc28ce
