Bump regexp_parser from 1.7.0 to 1.7.1 (PR #9998)
Bumps regexp_parser from 1.7.0 to 1.7.1.
Changelog
Sourced from regexp_parser's changelog.
[1.7.1] - 2020-06-07 - Ammar Ali
Fixed
  • Support for literals that include the unescaped delimiters {, }, and ]. These delimiters are informally supported by various regexp engines.
Commits
GitHub
Looks like regexp_parser is up-to-date now, so this is no longer needed.
