Bump rexml from 3.2.4 to 3.2.5 (PR #25)
Bumps rexml from 3.2.4 to 3.2.5.
Changelog
Sourced from rexml's changelog.
3.2.5 - 2021-04-05 {#version-3-2-5}
Improvements
  • Add more validations to XPath parser.
  • require "rexml/document" by default. [GitHub#36][Patch by Koichi ITO]
  • Don't add #dcloe method to core classes globally. [GitHub#37][Patch by Akira Matsuda]
  • Add more documentations. [Patch by Burdette Lamar]
  • Added REXML::Elements#parent. [GitHub#52][Patch by Burdette Lamar]
Fixes
Thanks
  • Koichi ITO
  • Akira Matsuda
  • Burdette Lamar
  • Juho Nurminen
Commits
  • a622645 Add 3.2.5 entry
  • 3c137eb Fix a parser bug that some data may be ignored before DOCTYPE
  • 9b311e5 Fix a bug that invalid document declaration may be accepted
  • f9d88e4 Fix a bug that invalid document declaration may be generated
  • f7bab89 Fix a bug that invalid element end may be accepted
  • 6a250d2 Fix a bug that invalid element start may be accepted
  • 2fe62e2 Fix a bug that invalid notation declaration may be accepted
  • a659c63 Fix a bug that invalid notation declaration may be generated
  • 790dd11 Use ruby/setup-ruby (#66)
  • eda1b20 Clean up and enhance high-level RDoc (#65)
  • Additional commits viewable in compare view
You can disable automated security fix PRs for this repo from the Security Alerts page.
GitHub
