Bump rubocop from 0.85.0 to 0.85.1 (PR #9997)
Bumps rubocop from 0.85.0 to 0.85.1.
Release notes
Sourced from rubocop's releases.
RuboCop 0.85.1
Bug fixes
  • #8083: Fix an error for Lint/MixedRegexpCaptureTypes cop when using a regular expression that cannot be processed by regexp_parser gem. (@koic)
  • #8081: Fix a false positive for Lint/SuppressedException when empty rescue block in do block. (@koic)
  • #8096: Fix a false positive for Lint/SuppressedException when empty rescue block in defs. (@koic)
  • #8108: Fix infinite loop in Layout/HeredocIndentation auto-correct. (@jonas054)
  • #8042: Fix raising error in Lint::FormatParameterMismatch when it handles invalid format strings and add new offense. (@andrykonchin)
Changelog
Sourced from rubocop's changelog.
0.85.1 (2020-06-07)
Bug fixes
  • #8083: Fix an error for Lint/MixedRegexpCaptureTypes cop when using a regular expression that cannot be processed by regexp_parser gem. ([@koic][])
  • #8081: Fix a false positive for Lint/SuppressedException when empty rescue block in do block. ([@koic][])
  • #8096: Fix a false positive for Lint/SuppressedException when empty rescue block in defs. ([@koic][])
  • #8108: Fix infinite loop in Layout/HeredocIndentation auto-correct. ([@jonas054][])
  • #8042: Fix raising error in Lint::FormatParameterMismatch when it handles invalid format strings and add new offense. ([@andrykonchin][])
Commits
  • 01d717b Cut 0.85.1
  • 11dce97 Ignore bundle binstubs
  • acdab2e Add offense to Lint::FormatParameterMismatch about invalid format string
  • 937f549 Fix Lint::FormatParameterMismatch cop
  • 672e7fa [Fix #7472] Adopt Ruby's COC
  • dc757dd Merge pull request #8109 from jonas054/8108_heredoc_trailing_ws_infinite_loop
  • 32de264 [Fix #8108] Disregard whitespace lines in HeredocIndentation
  • 20f1231 Refactor cop; call to_a on COMPARISON_OPERATORS
  • 3425ac1 [Docs] Kill the last remaining legacy pages
  • 0345eb4 [Docs] Kill a few more legacy pages
  • Additional commits viewable in compare view
GitHub
