Bump y18n from 4.0.0 to 4.0.1 (PR #23)
Bumps y18n from 4.0.0 to 4.0.1.
Changelog
Sourced from y18n's changelog.
Change Log
All notable changes to this project will be documented in this file. See standard-version for commit guidelines.
5.0.5 (2020-10-25)
Bug Fixes
5.0.4 (2020-10-16)
Bug Fixes
  • exports: node 13.0 and 13.1 require the dotted object form with a string fallback (#105) (4f85d80)
5.0.3 (2020-10-16)
Bug Fixes
  • exports: node 13.0-13.6 require a string fallback (#103) (e39921e)
5.0.2 (2020-10-01)
Bug Fixes
5.0.1 (2020-09-05)
Bug Fixes
5.0.0 (2020-09-05)
⚠ BREAKING CHANGES
  • exports maps are now used, which modifies import behavior.
  • drops Node 6 and 4. begin following Node.js LTS schedule (#89)
Features
... (truncated)
Commits
Maintainer changes
This version was pushed to npm by oss-bot, a new releaser for y18n since your current version.
You can disable automated security fix PRs for this repo from the Security Alerts page.
GitHub
