Bump y18n from 5.0.2 to 5.0.8 (PR #52)
Bumps y18n from 5.0.2 to 5.0.8.
Release notes
Sourced from y18n's releases.
y18n y18n-v4.0.3
Bug Fixes
  • release: 4.x.x should not enforce Node 10 (#126) (1e21a53)
y18n y18n-v4.0.2
Bug Fixes
  • security: ensure entry exists for backport (#120) (b22c0df)
Changelog
Sourced from y18n's changelog.
5.0.8 (2021-04-07)
Bug Fixes
  • deno: force modern release for Deno (b1c215a)
5.0.7 (2021-04-07)
Bug Fixes
5.0.6 (2021-04-05)
Bug Fixes
  • webpack: skip readFileSync if not defined (#117) (6966fa9)
5.0.5 (2020-10-25)
Bug Fixes
5.0.4 (2020-10-16)
Bug Fixes
  • exports: node 13.0 and 13.1 require the dotted object form with a string fallback (#105) (4f85d80)
5.0.3 (2020-10-16)
Bug Fixes
  • exports: node 13.0-13.6 require a string fallback (#103) (e39921e)
Commits
You can disable automated security fix PRs for this repo from the Security Alerts page.
GitHub
