copyedit to shorten customize pills
diff --git a/config/locales/client.en.yml b/config/locales/client.en.yml
index aad6399..7276033 100644
--- a/config/locales/client.en.yml
+++ b/config/locales/client.en.yml
@@ -2562,7 +2562,7 @@ en:
       security: "Security"
       special_warning: "Warning: This category is a pre-seeded category and the security settings cannot be edited. If you do not wish to use this category, delete it instead of repurposing it."
       uncategorized_security_warning: "This category is special. It is intended as holding area for topics that have no category; it cannot have security settings."
-      uncategorized_general_warning: 'This category is special. It is used as the default category for new topics that do not have a category selected. If you want to prevent this behavior and force category selection, <a href="%{settingLink}">please disable the setting here</a>. If you want to change the name or description, go to <a href="%{customizeLink}">Customize / Text Content</a>.'
+      uncategorized_general_warning: 'This category is special. It is used as the default category for new topics that do not have a category selected. If you want to prevent this behavior and force category selection, <a href="%{settingLink}">please disable the setting here</a>. If you want to change the name or description, go to <a href="%{customizeLink}">Customize / Text</a>.'
       images: "Images"
       email_in: "Custom incoming email address:"
       email_in_allow_strangers: "Accept emails from anonymous users with no accounts"
@@ -3436,7 +3436,7 @@ en:
         copy_to_clipboard_error: "Error copying data to Clipboard"
         theme_owner: "Not editable, owned by:"
         email_templates:
-          title: "Email Templates"
+          title: "Email"
           subject: "Subject"
           multiple_subjects: "This email template has multiple subjects."
           body: "Body"
@@ -4137,7 +4137,7 @@ en:
       site_text:
         description: "You can customize any of the text on your forum. Please start by searching below:"
         search: "Search for the text you'd like to edit"
-        title: "Text Content"
+        title: "Text"
         edit: "edit"
         revert: "Revert Changes"
         revert_confirm: "Are you sure you want to revert your changes?"
diff --git a/config/locales/server.en.yml b/config/locales/server.en.yml
index 74a2b8e..b61be6b 100644
--- a/config/locales/server.en.yml
+++ b/config/locales/server.en.yml
@@ -1304,7 +1304,7 @@ en:
   site_settings:
     censored_words: "Words that will be automatically replaced with &#9632;&#9632;&#9632;&#9632;"
     delete_old_hidden_posts: "Auto-delete any hidden posts that stay hidden for more than 30 days."
-    default_locale: "The default language of this Discourse instance. You can replace the text of system generated categories and topics at <a href='%{base_path}/admin/customize/site_texts' target='_blank'>Customize / Text Content</a>."
+    default_locale: "The default language of this Discourse instance. You can replace the text of system generated categories and topics at <a href='%{base_path}/admin/customize/site_texts' target='_blank'>Customize / Text</a>."
     allow_user_locale: "Allow users to choose their own language interface preference"
     set_locale_from_accept_language_header: "set interface language for anonymous users from their web browser's language headers. (EXPERIMENTAL, does not work with anonymous cache)"
     support_mixed_text_direction: "Support mixed left-to-right and right-to-left text directions."
GitHub sha: a49aa895
