Correct filename typo
diff --git a/spec/components/validators/category_search_priority_weights_validator_spec.rb b/spec/components/validators/category_search_priority_weights_validator_spec.rb
new file mode 100644
index 0000000..d002370
--- /dev/null
+++ b/spec/components/validators/category_search_priority_weights_validator_spec.rb
@@ -0,0 +1,28 @@
+require 'rails_helper'
+require 'validators/category_search_priority_weights_validator'
+RSpec.describe CategorySearchPriorityWeightsValidator do
+  it "should validate the results correctly" do
+    expect do
+      SiteSetting.category_search_priority_very_low_weight = 0.9
+    end.to raise_error(Discourse::InvalidParameters)
+    [1, 0].each do |value|
+      expect do
+        SiteSetting.category_search_priority_low_weight = value
+    end
+    ['0.2', 10].each do |value|
+      expect do
+        SiteSetting.category_search_priority_high_weight = value
+    end
+    expect do
+      SiteSetting.category_search_priority_very_high_weight = 1.1
+  end
+end
diff --git a/spec/components/validators/category_searrch_priority_weights_validator_spec.rb b/spec/components/validators/category_searrch_priority_weights_validator_spec.rb
deleted file mode 100644
index d002370..0000000
--- a/spec/components/validators/category_searrch_priority_weights_validator_spec.rb
+++ /dev/null
@@ -1,28 +0,0 @@
-# frozen_string_literal: true
-require 'rails_helper'
-require 'validators/category_search_priority_weights_validator'
-RSpec.describe CategorySearchPriorityWeightsValidator do
-  it "should validate the results correctly" do
-    expect do
-      SiteSetting.category_search_priority_very_low_weight = 0.9
-    end.to raise_error(Discourse::InvalidParameters)
-    [1, 0].each do |value|
-      expect do
-        SiteSetting.category_search_priority_low_weight = value
-    end
-    ['0.2', 10].each do |value|
-      expect do
-        SiteSetting.category_search_priority_high_weight = value
-    end
-    expect do
-      SiteSetting.category_search_priority_very_high_weight = 1.1
-  end
-end
GitHub sha: df02930c
