Correct interpolation key
diff --git a/config/locales/client.en.yml b/config/locales/client.en.yml
index b046ebd..1230635 100644
--- a/config/locales/client.en.yml
+++ b/config/locales/client.en.yml
@@ -2391,7 +2391,7 @@ en:
       security: "Security"
       special_warning: "Warning: This category is a pre-seeded category and the security settings cannot be edited. If you do not wish to use this category, delete it instead of repurposing it."
       uncategorized_security_warning: "This category is special. It is intended as holding area for topics that have no category; it cannot have security settings."
-      uncategorized_general_warning: 'This category is special. It is used as the default category for new topics that do not have a category selected. If you want to prevent this behavior and force category selection, <a href="%{link}">please disable the setting here</a>. If you want to change the name or description, go to <a href="%{customizeLink}">Customize / Text Content</a>.'
+      uncategorized_general_warning: 'This category is special. It is used as the default category for new topics that do not have a category selected. If you want to prevent this behavior and force category selection, <a href="%{settingLink}">please disable the setting here</a>. If you want to change the name or description, go to <a href="%{customizeLink}">Customize / Text Content</a>.'
       images: "Images"
       email_in: "Custom incoming email address:"
       email_in_allow_strangers: "Accept emails from anonymous users with no accounts"
GitHub sha: 9e09224e
