Create LICENSE
Create LICENSE
diff --git a/LICENSE b/LICENSE
new file mode 100644
index 0000000..d159169
--- /dev/null
+++ b/LICENSE
@@ -0,0 +1,339 @@
+                    GNU GENERAL PUBLIC LICENSE
+                       Version 2, June 1991
+ Copyright (C) 1989, 1991 Free Software Foundation, Inc.,
+ 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+ Everyone is permitted to copy and distribute verbatim copies
+ of this license document, but changing it is not allowed.
+                            Preamble
+  The licenses for most software are designed to take away your
+freedom to share and change it.  By contrast, the GNU General Public
+License is intended to guarantee your freedom to share and change free
+software--to make sure the software is free for all its users.  This
+General Public License applies to most of the Free Software
+Foundation's software and to any other program whose authors commit to
+using it.  (Some other Free Software Foundation software is covered by
+the GNU Lesser General Public License instead.)  You can apply it to
+your programs, too.
+  When we speak of free software, we are referring to freedom, not
+price.  Our General Public Licenses are designed to make sure that you
+have the freedom to distribute copies of free software (and charge for
+this service if you wish), that you receive source code or can get it
+if you want it, that you can change the software or use pieces of it
+in new free programs; and that you know you can do these things.
+  To protect your rights, we need to make restrictions that forbid
+anyone to deny you these rights or to ask you to surrender the rights.
+These restrictions translate to certain responsibilities for you if you
+distribute copies of the software, or if you modify it.
+  For example, if you distribute copies of such a program, whether
+gratis or for a fee, you must give the recipients all the rights that
+you have.  You must make sure that they, too, receive or can get the
+source code.  And you must show them these terms so they know their
+rights.
+  We protect your rights with two steps: (1) copyright the software, and
+(2) offer you this license which gives you legal permission to copy,
+distribute and/or modify the software.
+  Also, for each author's protection and ours, we want to make certain
+that everyone understands that there is no warranty for this free
+software.  If the software is modified by someone else and passed on, we
+want its recipients to know that what they have is not the original, so
+that any problems introduced by others will not reflect on the original
+authors' reputations.
+  Finally, any free program is threatened constantly by software
+patents.  We wish to avoid the danger that redistributors of a free
+program will individually obtain patent licenses, in effect making the
+program proprietary.  To prevent this, we have made it clear that any
+patent must be licensed for everyone's free use or not licensed at all.
+  The precise terms and conditions for copying, distribution and
+modification follow.
+   TERMS AND CONDITIONS FOR COPYING, DISTRIBUTION AND MODIFICATION
+  0. This License applies to any program or other work which contains
+a notice placed by the copyright holder saying it may be distributed
+under the terms of this General Public License.  The "Program", below,
+refers to any such program or work, and a "work based on the Program"
+means either the Program or any derivative work under copyright law:
+that is to say, a work containing the Program or a portion of it,
+either verbatim or with modifications and/or translated into another
+language.  (Hereinafter, translation is included without limitation in
+the term "modification".)  Each licensee is addressed as "you".
+Activities other than copying, distribution and modification are not
+covered by this License; they are outside its scope.  The act of
+running the Program is not restricted, and the output from the Program
+is covered only if its contents constitute a work based on the
+Program (independent of having been made by running the Program).
+Whether that is true depends on what the Program does.
+  1. You may copy and distribute verbatim copies of the Program's
+source code as you receive it, in any medium, provided that you
+conspicuously and appropriately publish on each copy an appropriate
+copyright notice and disclaimer of warranty; keep intact all the
+notices that refer to this License and to the absence of any warranty;
+and give any other recipients of the Program a copy of this License
+along with the Program.
+You may charge a fee for the physical act of transferring a copy, and
+you may at your option offer warranty protection in exchange for a fee.
+  2. You may modify your copy or copies of the Program or any portion
+of it, thus forming a work based on the Program, and copy and
+distribute such modifications or work under the terms of Section 1
+above, provided that you also meet all of these conditions:
+    a) You must cause the modified files to carry prominent notices
+    stating that you changed the files and the date of any change.
+    b) You must cause any work that you distribute or publish, that in
+    whole or in part contains or is derived from the Program or any
+    part thereof, to be licensed as a whole at no charge to all third
+    parties under the terms of this License.
+    c) If the modified program normally reads commands interactively
+    when run, you must cause it, when started running for such
+    interactive use in the most ordinary way, to print or display an
+    announcement including an appropriate copyright notice and a
+    notice that there is no warranty (or else, saying that you provide
+    a warranty) and that users may redistribute the program under
+    these conditions, and telling the user how to view a copy of this
+    License.  (Exception: if the Program itself is interactive but
+    does not normally print such an announcement, your work based on
+    the Program is not required to print an announcement.)
+These requirements apply to the modified work as a whole.  If
+identifiable sections of that work are not derived from the Program,
+and can be reasonably considered independent and separate works in
+themselves, then this License, and its terms, do not apply to those
+sections when you distribute them as separate works.  But when you
+distribute the same sections as part of a whole which is a work based
+on the Program, the distribution of the whole must be on the terms of
+this License, whose permissions for other licensees extend to the
+entire whole, and thus to each and every part regardless of who wrote it.
+Thus, it is not the intent of this section to claim rights or contest
+your rights to work written entirely by you; rather, the intent is to
+exercise the right to control the distribution of derivative or
+collective works based on the Program.
+In addition, mere aggregation of another work not based on the Program
+with the Program (or with a work based on the Program) on a volume of
+a storage or distribution medium does not bring the other work under
+the scope of this License.
+  3. You may copy and distribute the Program (or a work based on it,
+under Section 2) in object code or executable form under the terms of
+Sections 1 and 2 above provided that you also do one of the following:
+    a) Accompany it with the complete corresponding machine-readable
+    source code, which must be distributed under the terms of Sections
+    1 and 2 above on a medium customarily used for software interchange; or,
+    b) Accompany it with a written offer, valid for at least three
+    years, to give any third party, for a charge no more than your
+    cost of physically performing source distribution, a complete
+    machine-readable copy of the corresponding source code, to be
GitHub sha: 595fb4c1564bf4f0eeaf0ee0667e3dd8854fbf1e
