Delete deprecated controller
diff --git a/app/controllers/discourse_akismet/admin_mod_queue_controller.rb b/app/controllers/discourse_akismet/admin_mod_queue_controller.rb
deleted file mode 100644
index 9d22385..0000000
--- a/app/controllers/discourse_akismet/admin_mod_queue_controller.rb
+++ /dev/null
@@ -1,111 +0,0 @@
-# frozen_string_literal: true
-module DiscourseAkismet
-  class AdminModQueueController < Admin::AdminController
-    requires_plugin 'discourse-akismet'
-    before_action :deprecation_notice
-    def index
-      render_json_dump(
-        posts: serialize_data(DiscourseAkismet.needs_review, PostSerializer, add_excerpt: true),
-        enabled: SiteSetting.akismet_enabled?,
-        stats: DiscourseAkismet.stats
-    end
-    def confirm_spam
-      if should_use_reviewable_api?
-        reviewable.perform(current_user, :confirm_spam)
-      else
-        DiscourseAkismet.move_to_state(post, 'confirmed_spam')
-        log_confirmation(post, 'confirmed_spam')
-      end
-      render body: nil
-    end
-    def allow
-        reviewable.perform(current_user, :not_spam)
-      else
-        Jobs.enqueue(:update_akismet_status, post_id: post.id, status: 'ham')
-        # It's possible the post was recovered already
-        PostDestroyer.new(current_user, post).recover if post.deleted_at
-        DiscourseAkismet.move_to_state(post, 'confirmed_ham')
-        log_confirmation(post, 'confirmed_ham')
-      end
-      render body: nil
-    end
-    def dismiss
-        reviewable.perform(current_user, :ignore)
-      else
-        DiscourseAkismet.move_to_state(post, 'dismissed')
-        log_confirmation(post, 'ignored')
-      end
-      render body: nil
-    end
-    def delete_user
-        reviewable.perform(current_user, :confirm_delete)
-      else
-        user = post.user
-        log_confirmation(post, 'confirmed_spam_deleted')
-        if guardian.can_delete_user?(user)
-          UserDestroyer.new(current_user).destroy(user, user_deletion_opts)
-        end
-      end
-      render body: nil
-    end
-    private
-    def should_use_reviewable_api?
-      defined?(ReviewableAkismetPost) && reviewable
-    end
-    def log_confirmation(post, custom_type)
-      topic = post.topic || Topic.with_deleted.find(post.topic_id)
-      StaffActionLogger.new(current_user).log_custom(custom_type,
-        post_id: post.id,
-        topic_id: topic.id
-    end
-    def user_deletion_opts
-      base = {
-        context: I18n.t('akismet.delete_reason', performed_by: current_user.username),
-        delete_posts: true
-      if Rails.env.production? && ENV["Staging"].nil?
-        base.merge!(block_email: true, block_ip: true)
-      end
-      base
-    end
-    def deprecation_notice
-      Discourse.deprecate('Akismet review queue is deprecated. Please use the reviewable API instead.')
-    end
-    def reviewable
-      @reviewable ||= ReviewableAkismetPost.find_by(target_id: params[:post_id], target_type: Post.name)
-    end
-    def post
-      @post ||= Post.with_deleted.find(params[:post_id])
-    end
-  end
-end
GitHub sha: 74a43234
