DEPRECATED: create_private_message (#236)
create_private_message has been deprecated to remove the use of the target_usernames parameter. A deprecation warning message will now be outputed if you use that method. Please use create_pm from now on with the target_recipients param.
diff --git a/lib/discourse_api/api/private_messages.rb b/lib/discourse_api/api/private_messages.rb
index 684d07d..1fde19c 100644
--- a/lib/discourse_api/api/private_messages.rb
+++ b/lib/discourse_api/api/private_messages.rb
@@ -3,13 +3,20 @@ module DiscourseApi
   module API
     module PrivateMessages
-      # :target_usernames REQUIRED comma separated list of usernames
+      # TODO: Deprecated. Remove after 20220628
+      def create_private_message(args = {})
+        deprecated(__method__, 'create_pm')
+        args[:target_recipients] = args.delete :target_usernames
+        create_pm(args.to_h)
+      end
+      # :target_recipients REQUIRED comma separated list of usernames
       # :category OPTIONAL name of category, not ID
       # :created_at OPTIONAL seconds since epoch.
-      def create_private_message(args = {})
+      def create_pm(args = {})
         args[:archetype] = 'private_message'
         args = API.params(args)
-          .required(:title, :raw, :target_usernames, :archetype)
+          .required(:title, :raw, :target_recipients, :archetype)
           .optional(:category, :created_at, :api_username)
         post("/posts", args.to_h)
diff --git a/spec/discourse_api/api/private_messages_spec.rb b/spec/discourse_api/api/private_messages_spec.rb
index 514fb33..ad8dfda 100644
--- a/spec/discourse_api/api/private_messages_spec.rb
+++ b/spec/discourse_api/api/private_messages_spec.rb
@@ -36,19 +36,19 @@ describe DiscourseApi::API::PrivateMessages do
-  describe '#create_private_message' do
+  describe '#create_pm' do
     before do
       stub_post("#{host}/posts")
-      subject.create_private_message(
+      subject.create_pm(
         title: "Confidential: Hello World!",
         raw: "This is the raw markdown for my private message",
-        target_usernames: "user1,user2"
+        target_recipients: "user1,user2"
     it "makes a create private message request" do
       expect(a_post("#{host}/posts").with(body:
-          'archetype=private_message&raw=This+is+the+raw+markdown+for+my+private+message&target_usernames=user1%2Cuser2&title=Confidential%3A+Hello+World%21')
+          'archetype=private_message&raw=This+is+the+raw+markdown+for+my+private+message&target_recipients=user1%2Cuser2&title=Confidential%3A+Hello+World%21')
         ).to have_been_made
GitHub sha: a459d434f6340aeef16ec5fec766ac3f56cefeef
This commit appears in #236 which was approved by eviltrout. It was merged by blake.
