DEV: Abort autospec on [ENTER], even if no specs have failed (PR #8320)
When starting autospec, it says
Press [ENTER] to stop the current run
However, [ENTER] does nothing unless a spec has failed. Sometimes I want to abort anyway, so that the run is restarted.
GitHub
You’ve signed the CLA, davidtaylorhq. Thank you! This pull request is ready for review.
Thank you, I’ve often wanted this.
