DEV: Add a verbose option to ./bin/turbo_rspec
diff --git a/bin/turbo_rspec b/bin/turbo_rspec
index 0d96601..e0af6b3 100755
--- a/bin/turbo_rspec
+++ b/bin/turbo_rspec
@@ -6,6 +6,7 @@ require 'optparse'
 requires = []
 formatters = []
+verbose = false
 OptionParser.new do |opts|
   opts.on("-r", "--require PATH", "Require a file.") do |filename|
@@ -28,6 +29,10 @@ OptionParser.new do |opts|
     formatters.last[:outputs] << filename
+  opts.on("-v", "--verbose", "More output") do
+    verbose = true
+  end
 end.parse!(ARGV)
 requires.each { |f| require(f) }
@@ -45,4 +50,8 @@ formatters.each do |formatter|
-TurboTests::Runner.run(formatters, ARGV.empty? ? ["spec"] : ARGV)
+TurboTests::Runner.run(
+  formatters: formatters,
+  files: ARGV.empty? ? ["spec"] : ARGV,
+  verbose: verbose
diff --git a/lib/tasks/turbo.rake b/lib/tasks/turbo.rake
index 48c5a91..e78b2f2 100644
--- a/lib/tasks/turbo.rake
+++ b/lib/tasks/turbo.rake
@@ -3,5 +3,8 @@
 task 'turbo:spec' => :test do |t|
   require './lib/turbo_tests'
-  TurboTests::Runner.run([{ name: 'progress', outputs: ['-'] }], ['spec'])
+  TurboTests::Runner.run(
+    formatters: [{ name: 'progress', outputs: ['-'] }],
+    files: ['spec']
diff --git a/lib/turbo_tests/runner.rb b/lib/turbo_tests/runner.rb
index 9f9b78d..650e5fe 100644
--- a/lib/turbo_tests/runner.rb
+++ b/lib/turbo_tests/runner.rb
@@ -2,15 +2,30 @@
 module TurboTests
   class Runner
-    def self.run(formatter_config, files, start_time = Time.now)
-      reporter = Reporter.from_config(formatter_config, start_time)
+    def self.run(opts = {})
+      files = opts[:files]
+      formatters = opts[:formatters]
+      start_time = opts.fetch(:start_time) { Time.now }
+      verbose = opts.fetch(:verbose, false)
+      if verbose
+        STDERR.puts "VERBOSE"
+      end
+      reporter = Reporter.from_config(formatters, start_time)
-      new(reporter, files).run
+      new(
+        reporter: reporter,
+        files: files,
+        verbose: verbose
+      ).run
-    def initialize(reporter, files)
-      @reporter = reporter
-      @files = files
+    def initialize(opts)
+      @reporter = opts[:reporter]
+      @files = opts[:files]
+      @verbose = opts[:verbose]
       @messages = Queue.new
       @threads = []
@@ -61,14 +76,24 @@ module TurboTests
         rescue Errno::EEXIST
-        _stdin, stdout, stderr, _wait_thr =
-          Open3.popen3(
-            { 'TEST_ENV_NUMBER' => process_num.to_s },
-            "bundle", "exec", "rspec",
-            "-f", "TurboTests::JsonRowsFormatter",
-            "-o", "tmp/test-pipes/subprocess-#{process_num}",
-            *tests
+        env = { 'TEST_ENV_NUMBER' => process_num.to_s }
+        command = [
+          "bundle", "exec", "rspec",
+          "-f", "TurboTests::JsonRowsFormatter",
+          "-o", "tmp/test-pipes/subprocess-#{process_num}",
+          *tests
+        if @verbose
+          command_str = [
+            env.map { |k, v| "#{k}=#{v}" }.join(' '),
+            command.join(' ')
+          ].join(' ')
+          STDERR.puts "Process #{process_num}: #{command_str}"
+        end
+        _stdin, stdout, stderr, _wait_thr = Open3.popen3(env, *command)
         @threads <<
           Thread.new do
GitHub sha: d6aa92e9
