DEV: Add additional hooks for theme-creator plugin
diff --git a/app/assets/javascripts/admin/controllers/modals/admin-import-theme.js.es6 b/app/assets/javascripts/admin/controllers/modals/admin-import-theme.js.es6
index 325cc4a..1c7752e 100644
--- a/app/assets/javascripts/admin/controllers/modals/admin-import-theme.js.es6
+++ b/app/assets/javascripts/admin/controllers/modals/admin-import-theme.js.es6
@@ -76,6 +76,11 @@ export default Ember.Controller.extend(ModalFunctionality, {
+      if (this.get("model.user_id")) {
+        // Used by theme-creator
+        options.data["user_id"] = this.get("model.user_id");
       this.set("loading", true);
       ajax(this.get("importUrl"), options)
         .then(result => {
diff --git a/app/controllers/admin/themes_controller.rb b/app/controllers/admin/themes_controller.rb
index 31bda27..edf6fa4 100644
--- a/app/controllers/admin/themes_controller.rb
+++ b/app/controllers/admin/themes_controller.rb
@@ -17,7 +17,7 @@ class Admin::ThemesController < Admin::AdminController
     hijack do
       File.open(path) do |file|
         filename = params[:file]&.original_filename || File.basename(path)
-        upload = UploadCreator.new(file, filename, for_theme: true).create_for(current_user.id)
+        upload = UploadCreator.new(file, filename, for_theme: true).create_for(theme_user.id)
         if upload.errors.count > 0
           render_json_error upload
         else
@@ -44,7 +44,7 @@ class Admin::ThemesController < Admin::AdminController
       json = JSON::parse(params[:theme].read)
       theme = json['theme']
-      @theme = Theme.new(name: theme["name"], user_id: current_user.id)
+      @theme = Theme.new(name: theme["name"], user_id: theme_user.id)
       theme["theme_fields"]&.each do |field|
         if field["raw_upload"]
@@ -54,7 +54,7 @@ class Admin::ThemesController < Admin::AdminController
             file = Base64.decode64(field["raw_upload"])
             tmp.write(file)
             tmp.rewind
-            upload = UploadCreator.new(tmp, field["filename"]).create_for(current_user.id)
+            upload = UploadCreator.new(tmp, field["filename"]).create_for(theme_user.id)
             field["upload_id"] = upload.id
           ensure
             tmp.unlink
@@ -79,7 +79,7 @@ class Admin::ThemesController < Admin::AdminController
     elsif params[:remote]
       begin
         branch = params[:branch] ? params[:branch] : nil
-        @theme = RemoteTheme.import_theme(params[:remote], current_user, private_key: params[:private_key], branch: branch)
+        @theme = RemoteTheme.import_theme(params[:remote], theme_user, private_key: params[:private_key], branch: branch)
         render json: @theme, status: :created
       rescue RemoteTheme::ImportError => e
         render_json_error e.message
@@ -90,7 +90,7 @@ class Admin::ThemesController < Admin::AdminController
       theme_id = params[:theme_id]
       match_theme_by_name = !!params[:bundle] && !params.key?(:theme_id) # Old theme CLI behavior, match by name. Remove Jan 2020
       begin
-        @theme = RemoteTheme.update_tgz_theme(bundle.path, match_theme: match_theme_by_name, user: current_user, theme_id: theme_id)
+        @theme = RemoteTheme.update_tgz_theme(bundle.path, match_theme: match_theme_by_name, user: theme_user, theme_id: theme_id)
         log_theme_change(nil, @theme)
@@ -129,7 +129,7 @@ class Admin::ThemesController < Admin::AdminController
   def create
     @theme = Theme.new(name: theme_params[:name],
-                       user_id: current_user.id,
+                       user_id: theme_user.id,
                        user_selectable: theme_params[:user_selectable] || false,
                        color_scheme_id: theme_params[:color_scheme_id],
                        component: [true, "true"].include?(theme_params[:component]))
@@ -316,4 +316,9 @@ class Admin::ThemesController < Admin::AdminController
       @theme.switch_to_component!
+  # Overridden by theme-creator plugin
+  def theme_user
+    current_user
+  end
GitHub sha: 59640ef3
This is so rare that I guess it is ok for now, an alternative here is Plugin::Filter.
We don’t use this that much, but it is a more “stable” way of providing extensiblity
Plugin::Filter.register(:lookup_admin_theme_user) do
   # return the user here
That said, this is such an edge case that I do not recommend this way and I am not sure if long term we will keep the filter api cause there have been so few consumers.
