DEV: Add class to header-topic-info widget (PR #9475)
There is an .extra-info-wrapper holding the .extra-info div. Right now, a .two-rows class gets added to .extra-info when viewing a topic with a category showing. If the topic is uncategorized, and suppress uncategorized is true, the .two-rows class is not present.
In some plugins we decorate this widget like so: header-topic-info:after. The problem here is that we need the two-rows class to be on the PARENT of header-topic-info so that we can use it as a css selector.
GitHub
do we need the .get here ?
I can remove it!
I’m curious why don’t we directly use category here ?
and attrs.topic.category here ?
I like the function name with topic as argument.
Should we show the category for the given topic?
Same as above. I can change it, but I do like how it reads.
well ok then :+1:
