DEV: Add external_id to notification payload
If sso is enabled the notification payload will now include the external_id for the user.
This was requested on meta: https://meta.discourse.org/t/-/129052/10
diff --git a/app/serializers/notification_serializer.rb b/app/serializers/notification_serializer.rb
index e01e639..18f0b9f 100644
--- a/app/serializers/notification_serializer.rb
+++ b/app/serializers/notification_serializer.rb
@@ -4,6 +4,7 @@ class NotificationSerializer < ApplicationSerializer
   attributes :id,
              :user_id,
+             :external_id,
              :notification_type,
              :read,
              :created_at,
@@ -38,4 +39,12 @@ class NotificationSerializer < ApplicationSerializer
     object.data_hash
+  def external_id
+    object.user&.single_sign_on_record&.external_id
+  end
+  def include_external_id?
+    SiteSetting.enable_sso
+  end
diff --git a/spec/serializers/notification_serializer_spec.rb b/spec/serializers/notification_serializer_spec.rb
index 63f305e..afa0324 100644
--- a/spec/serializers/notification_serializer_spec.rb
+++ b/spec/serializers/notification_serializer_spec.rb
@@ -13,5 +13,26 @@ describe NotificationSerializer do
       expect(json[:notification][:user_id]).to eq(user.id)
+    it "does not include external_id when sso is disabled" do
+      expect(json[:notification].key?(:external_id)).to eq(false)
+    end
+  end
+  describe '#sso_enabled' do
+    let :user do
+      user = Fabricate(:user)
+      SingleSignOnRecord.create!(user_id: user.id, external_id: '12345', last_payload: '')
+      user
+    end
+    let(:notification) { Fabricate(:notification, user: user) }
+    let(:serializer) { NotificationSerializer.new(notification) }
+    let(:json) { serializer.as_json }
+    it "should include the external_id" do
+      SiteSetting.sso_url = "http://example.com/discourse_sso"
+      SiteSetting.sso_secret = "12345678910"
+      SiteSetting.enable_sso = true
+      expect(json[:notification][:external_id]).to eq("12345")
+    end
GitHub sha: a900c999
https://meta.discourse.org/t/getting-the-target-user-for-notification-webhook-events/129052/11
