DEV: Add more API Doc specs for topic endpoints
Added some more specs that will be used to auto generate the api docs.
Added timed topic and update timestamp endpoints.
diff --git a/spec/requests/api/topics_spec.rb b/spec/requests/api/topics_spec.rb
index f5c9f8d..a5bcf14 100644
--- a/spec/requests/api/topics_spec.rb
+++ b/spec/requests/api/topics_spec.rb
@@ -884,4 +884,84 @@ describe 'posts' do
+  path '/t/{id}/change-timestamp.json' do
+    put 'Update topic timestamp' do
+      tags 'Topics'
+      consumes 'application/json'
+      parameter name: 'Api-Key', in: :header, type: :string, required: true
+      parameter name: 'Api-Username', in: :header, type: :string, required: true
+      parameter name: :id, in: :path, schema: { type: :string }
+      parameter name: :request_body, in: :body, schema: {
+        type: :object,
+        properties: {
+          timestamp: {
+            type: :string,
+            example: '1594291380'
+        }, required: [ 'timestamp' ]
+      produces 'application/json'
+      response '200', 'topic updated' do
+        schema type: :object, properties: {
+          success: { type: :string },
+        let(:request_body) { { timestamp: '1594291380' } }
+        let!(:post) { Fabricate(:post) }
+        let(:id) { post.topic.id }
+        run_test!
+      end
+    end
+  end
+  path '/t/{id}/timer.json' do
+    post 'Create topic timer' do
+      tags 'Topics'
+        type: :object,
+        properties: {
+          time: {
+            type: :string,
+            example: ''
+          status_type: {
+            type: :string,
+          based_on_last_post: {
+            type: :boolean,
+          category_id: {
+            type: :integer
+          execute_at: { type: :string },
+          duration: { type: :string, nullable: true },
+          based_on_last_post: { type: :boolean },
+          closed: { type: :boolean },
+          category_id: { type: :string, nullable: true },
+        let(:request_body) { { time: '2020-07-11+18:00-06:00', status_type: 'close' } }
+        let!(:topic_post) { Fabricate(:post) }
+        let(:id) { topic_post.topic.id }
+        run_test!
+      end
+    end
+  end
GitHub sha: 544a9865
