DEV: Add more keyboard shortcut acceptance tests (#13280)
This adds acceptance tests for keyboard shortcuts to dismiss new and unread topics.
Also, I cleaned out a few old specs for the unit test for keyboard-shortcuts. Some were introduced way back in Add Global Keyboard Shortcuts · discourse/discourse@5100c2b · GitHub but then supplanted by FIX: Some keyboard commands should not fire when anonymous · discourse/discourse@9548876 · GitHub and never cleaned up, so they were doing nothing.
Follow up to FIX: Dismiss topics keyboard shortcut not working (PR #13260) - #4 by SamSaffron
diff --git a/app/assets/javascripts/discourse/app/templates/modal/dismiss-read.hbs b/app/assets/javascripts/discourse/app/templates/modal/dismiss-read.hbs
index 79d398d..b295e1f 100644
--- a/app/assets/javascripts/discourse/app/templates/modal/dismiss-read.hbs
+++ b/app/assets/javascripts/discourse/app/templates/modal/dismiss-read.hbs
@@ -9,5 +9,6 @@
     class="btn-primary"
     action=(route-action "dismissReadTopics" dismissTopics)
     icon="check"
+    id="dismiss-read-confirm"
     label="topics.bulk.dismiss"}}
 </div>
diff --git a/app/assets/javascripts/discourse/tests/acceptance/keyboard-shortcuts-test.js b/app/assets/javascripts/discourse/tests/acceptance/keyboard-shortcuts-test.js
index 7228638..bb316a1 100644
--- a/app/assets/javascripts/discourse/tests/acceptance/keyboard-shortcuts-test.js
+++ b/app/assets/javascripts/discourse/tests/acceptance/keyboard-shortcuts-test.js
@@ -1,8 +1,11 @@
 import { currentURL, triggerKeyEvent, visit } from "@ember/test-helpers";
-import { acceptance } from "discourse/tests/helpers/qunit-helpers";
+import { cloneJSON } from "discourse-common/lib/object";
+import I18n from "I18n";
+import { acceptance, queryAll } from "discourse/tests/helpers/qunit-helpers";
+import DiscoveryFixtures from "discourse/tests/fixtures/discovery-fixtures";
 import { test } from "qunit";
-acceptance("Keyboard Shortcuts", function (needs) {
+acceptance("Keyboard Shortcuts - Anonymous Users", function (needs) {
   needs.pretender((server, helper) => {
     server.get("/t/27331/4.json", () => helper.response({}));
     server.get("/t/27331.json", () => helper.response({}));
@@ -41,3 +44,93 @@ acceptance("Keyboard Shortcuts", function (needs) {
     assert.equal(currentURL(), "/t/keyboard-shortcuts-are-awesome/27331");
+acceptance("Keyboard Shortcuts - Authenticated Users", function (needs) {
+  let resetNewCalled;
+  let markReadCalled;
+  let topicList;
+  needs.user();
+  needs.hooks.beforeEach(() => {
+    resetNewCalled = 0;
+    markReadCalled = 0;
+  needs.pretender((server, helper) => {
+    topicList = cloneJSON(DiscoveryFixtures["/latest.json"]);
+    // get rid of some of the topics and the more_topics_url
+    // so we consider them allLoaded and show the footer with
+    // the bottom dismiss button
+    topicList.topic_list.topics.splice(20, 30);
+    topicList.topic_list.more_topics_url = null;
+    server.get("/unread.json", () => {
+      return helper.response(topicList);
+    server.get("/new.json", () => {
+    server.put("/topics/reset-new", () => {
+      resetNewCalled += 1;
+      return helper.response({});
+    server.put("/topics/bulk", () => {
+      markReadCalled += 1;
+  test("dismiss unread from top and bottom button", async function (assert) {
+    await visit("/unread");
+    await triggerKeyEvent(document, "keypress", "x".charCodeAt(0));
+    await triggerKeyEvent(document, "keypress", "t".charCodeAt(0));
+    assert.ok(exists("#dismiss-read-confirm"));
+    assert.equal(
+      queryAll(".modal-body").text().trim(),
+      I18n.t("topics.bulk.also_dismiss_topics")
+    await click("#dismiss-read-confirm");
+    assert.equal(markReadCalled, 1);
+    // we get rid of all but one topic so the top dismiss button doesn't
+    // show up, as it only appears if there are too many topics pushing
+    // the bottom button out of the viewport
+    let originalTopics = [...topicList.topic_list.topics];
+    topicList.topic_list.topics = [topicList.topic_list.topics[0]];
+    assert.equal(
+      "Stop tracking these topics so they never show up as unread for me again"
+    assert.equal(markReadCalled, 2);
+    // restore the original topic list
+    topicList.topic_list.topics = originalTopics;
+  test("dismiss new from top and bottom button", async function (assert) {
+    await visit("/new");
+    await triggerKeyEvent(document, "keypress", "r".charCodeAt(0));
+    assert.equal(resetNewCalled, 1);
+    assert.equal(resetNewCalled, 2);
diff --git a/app/assets/javascripts/discourse/tests/unit/lib/keyboard-shortcuts-test.js b/app/assets/javascripts/discourse/tests/unit/lib/keyboard-shortcuts-test.js
index fe9b717..149d219 100644
--- a/app/assets/javascripts/discourse/tests/unit/lib/keyboard-shortcuts-test.js
+++ b/app/assets/javascripts/discourse/tests/unit/lib/keyboard-shortcuts-test.js
@@ -3,117 +3,9 @@ import DiscourseURL from "discourse/lib/url";
 import KeyboardShortcuts from "discourse/lib/keyboard-shortcuts";
 import sinon from "sinon";
-let testMouseTrap;
 module("Unit | Utility | keyboard-shortcuts", function (hooks) {
   hooks.beforeEach(function () {
-    let _bindings = {};
-    testMouseTrap = {
-      bind: function (bindings, callback) {
-        let registerBinding = function (binding) {
-          _bindings[binding] = callback;
-        }.bind(this);
-        if (Array.isArray(bindings)) {
-          bindings.forEach(registerBinding, this);
-        } else {
-          registerBinding(bindings);
-      trigger: function (binding) {
-        _bindings[binding].call();
     sinon.stub(DiscourseURL, "routeTo");
-    $("#qunit-fixture").html(
-        "<article class='topic-post selected'>",
-        "<a class='post-date'></a>" + "</article>",
-        "<div class='notification-options'>",
-        "  <ul>",
-        "    <li data-id='0'><a></a></li>",
-        "    <li data-id='1'><a></a></li>",
-        "    <li data-id='2'><a></a></li>",
-        "    <li data-id='3'><a></a></li>",
-        "  </ul>",
-        "</div>",
-        "<table class='topic-list'>",
-        "  <tr class='topic-list-item selected'><td>",
-        "    <a class='title'></a>",
-        "  </td></tr>",
-        "</table>",
-        "<div id='topic-footer-buttons'>",
-        "  <button class='star'></button>",
-        "  <button class='create'></button>",
-        "  <button class='share'></button>",
-        "  <button id='dismiss-new-top'></button>",
-        "  <button id='dismiss-topics-top'></button>",
-        "</div>",
-        "<div class='alert alert-info clickable'></div>",
-        "<button id='create-topic'></button>",
-        "<div id='user-notifications'></div>",
-        "<div id='toggle-hamburger-menu'></div>",
-        "<div id='search-button'></div>",
-        "<div id='current-user'></div>",
-        "<div id='keyboard-help'></div>",
-      ].join("\n")
-  hooks.afterEach(function () {
-    $("#qunit-scratch").html("");
-    testMouseTrap = undefined;
-  let pathBindings = KeyboardShortcuts.PATH_BINDINGS || {};
-  Object.keys(pathBindings).forEach((path) => {
-    const binding = pathBindings[path];
-    let testName = binding + " goes to " + path;
-    test(testName, function (assert) {
-      KeyboardShortcuts.bindEvents();
-      testMouseTrap.trigger(binding);
GitHub sha: b01e4738
This commit appears in #13280 which was approved by tgxworld. It was merged by martin.
