DEV: add plugin hooks for silence message parameters (#10538)
Allows plugins to add, and update extra silence message params for custom i18n vars
Allows plugins to override system messages via message_title and message_raw parameters. We can later expose these params where necessary via event hooks. Expose the parameter for the on user_silenced trigger.
diff --git a/app/services/user_silencer.rb b/app/services/user_silencer.rb
index 9f192dc..335175c 100644
--- a/app/services/user_silencer.rb
+++ b/app/services/user_silencer.rb
@@ -36,7 +36,6 @@ class UserSilencer
         ).format
         context = "#{message_type}: '#{post.topic&.title rescue ''}' #{@opts[:reason]}"
-        SystemMessage.create(@user, message_type)
         if @by_user
           log_params = { context: context, details: details }
@@ -48,6 +47,7 @@ class UserSilencer
+        silence_message_params = {}
         DiscourseEvent.trigger(
           :user_silenced,
           user: @user,
@@ -57,8 +57,11 @@ class UserSilencer
           user_history: @user_history,
           post_id: @opts[:post_id],
           silenced_till: @user.silenced_till,
-          silenced_at: DateTime.now
+          silenced_at: DateTime.now,
+          silence_message_params: silence_message_params
+        SystemMessage.create(@user, message_type, silence_message_params)
         true
     else
diff --git a/lib/system_message.rb b/lib/system_message.rb
index b6eaab6..fd6e5af 100644
--- a/lib/system_message.rb
+++ b/lib/system_message.rb
@@ -21,8 +21,8 @@ class SystemMessage
     params = defaults.merge(params)
     from_system = params[:from_system] || false
-    title = I18n.with_locale(@recipient.effective_locale) { I18n.t("system_messages.#{type}.subject_template", params) }
-    raw = I18n.with_locale(@recipient.effective_locale) { I18n.t("system_messages.#{type}.text_body_template", params) }
+    title = params[:message_title] || I18n.with_locale(@recipient.effective_locale) { I18n.t("system_messages.#{type}.subject_template", params) }
+    raw = params[:message_raw] || I18n.with_locale(@recipient.effective_locale) { I18n.t("system_messages.#{type}.text_body_template", params) }
     if from_system
       user = Discourse.system_user
diff --git a/spec/components/system_message_spec.rb b/spec/components/system_message_spec.rb
index 088c19f..3c88d42 100644
--- a/spec/components/system_message_spec.rb
+++ b/spec/components/system_message_spec.rb
@@ -55,6 +55,19 @@ describe SystemMessage do
       ).count).to eq(0)
+    it 'allows message_title and message_raw ops to override content' do
+      user = Fabricate(:user)
+      system_user = Discourse.system_user
+      post = SystemMessage.create_from_system_user(user, :welcome_invite, { message_title: "override title", message_raw: "override body" })
+      topic = post.topic
+      expect(topic.private_message?).to eq(true)
+      expect(topic.title).to eq("override title")
+      expect(topic.subtype).to eq(TopicSubtype.system_message)
+      expect(post.raw).to eq("override body")
+    end
     it 'should allow site_contact_group_name' do
       group = Fabricate(:group)
       SiteSetting.site_contact_group_name = group.name
diff --git a/spec/services/user_silencer_spec.rb b/spec/services/user_silencer_spec.rb
index 66bb96a..dfe0c33 100644
--- a/spec/services/user_silencer_spec.rb
+++ b/spec/services/user_silencer_spec.rb
@@ -26,7 +26,7 @@ describe UserSilencer do
     context 'given a staff user argument' do
       it 'sends the correct message to the silenced user' do
         SystemMessage.unstub(:create)
-        SystemMessage.expects(:create).with(user, :silenced_by_staff).returns(true)
+        SystemMessage.expects(:create).with(user, :silenced_by_staff, {}).returns(true)
         UserSilencer.silence(user, Fabricate.build(:admin))
@@ -34,7 +34,7 @@ describe UserSilencer do
     context 'not given a staff user argument' do
       it 'sends a default message to the user' do
@@ -42,7 +42,7 @@ describe UserSilencer do
     context 'given a message option' do
       it 'sends that message to the user' do
-        SystemMessage.expects(:create).with(user, :the_custom_message).returns(true)
+        SystemMessage.expects(:create).with(user, :the_custom_message, {}).returns(true)
         UserSilencer.silence(user, Fabricate.build(:admin), message: :the_custom_message)
@@ -68,6 +68,29 @@ describe UserSilencer do
       }.to change { UserHistory.count }.by(1)
       expect(UserHistory.last.context).to be_present
+    context 'with a plugin hook' do
+      before do
+        @override_silence_message = -> (opts) do
+          opts[:silence_message_params][:message_title] = "override title"
+          opts[:silence_message_params][:message_raw] = "override raw"
+        end
+        DiscourseEvent.on(:user_silenced, &@override_silence_message)
+      end
+      after do
+        DiscourseEvent.off(:user_silenced, &@override_silence_message)
+      end
+      it 'allows the message to be overridden' do
+        SystemMessage.unstub(:create)
+        UserSilencer.silence(user, Fabricate.build(:admin))
+        post = Discourse.system_user.posts.last
+        expect(post.topic.title).to eq("override title")
+        expect(post.raw).to eq("override raw")
+      end
+    end
   describe 'unsilence' do
GitHub sha: d49e96c6
This commit appears in #10538 which was merged by featheredtoast.
