DEV: Add rake task for upgrading speedscope (#478)
  • DEV: Add rake task for upgrading speedscope
  • fix indentation
  • fix rubocop
diff --git a/Rakefile b/Rakefile
index 164aac2..79b2254 100644
--- a/Rakefile
+++ b/Rakefile
@@ -122,3 +122,102 @@ task :client_dev do
 rescue Interrupt
   listener.stop
+desc "Upgrade Speedscope to the latest version"
+task :speedscope_upgrade do
+  require 'net/http'
+  require 'json'
+  require 'tmpdir'
+  require 'zip'
+  puts "Checking GitHub for the latest version..."
+  releases_uri = URI('https://api.github.com/repos/jlfwong/speedscope/releases/latest')
+  req = Net::HTTP::Get.new(releases_uri, { 'Accept' => 'application/vnd.github.v3+json' })
+  http = Net::HTTP.new(releases_uri.hostname, releases_uri.port)
+  http.use_ssl = true
+  res = http.request(req)
+  if res.code.to_i != 200
+    puts "ERROR: GitHub responded with an unexpected status code: #{res.code.to_i}."
+    exit
+  end
+  latest_release_info = JSON.parse(res.body)
+  latest_version = latest_release_info['name'].sub('v', '')
+  speedscope_dir = File.expand_path('./lib/html/speedscope', __dir__)
+  current_version = File.read(File.join(speedscope_dir, 'release.txt')).split("\n")[0].split("@")[-1]
+  if latest_version == current_version
+    puts "Speedscope is already on the latest version (#{current_version.inspect})."
+    exit
+  end
+  puts "Current version is #{current_version.inspect} and latest version is: #{latest_version.inspect}"
+  asset = latest_release_info['assets'].find { |ast| ast['content_type'] == 'application/zip' }
+  asset_id = asset && asset['id']
+  if !asset_id
+    puts "ERROR: Couldn't find any zip files in the #{latest_version.inspect} release. "\
+         "Maybe the maintainer forgot to add one or the content type has changed. "\
+         "Please the check the releases page of the repository and/or contact the maintainer."
+    exit
+  end
+  Dir.mktmpdir do |temp_dir|
+    puts "Downloading zip file of latest release to #{temp_dir}..."
+    download_uri = URI("https://api.github.com/repos/jlfwong/speedscope/releases/assets/#{asset_id}")
+    req = Net::HTTP::Get.new(download_uri, { 'Accept' => 'application/octet-stream' })
+    http = Net::HTTP.new(download_uri.hostname, download_uri.port)
+    if res.code.to_i != 302
+      puts "ERROR: Expected a 302 status code from GitHub download URL but instead got #{res.code.inspect}."
+      exit
+    end
+    aws_uri = URI(res['Location'])
+    http = Net::HTTP.new(aws_uri.host, aws_uri.port)
+    request = Net::HTTP::Get.new(aws_uri)
+    temp_zip_file = File.join(temp_dir, "speedscope-v#{latest_version}.zip")
+    http.request(request) do |response|
+      if response.code.to_i != 200
+        puts "ERROR: Expected a 200 status code from download URL but instead got #{res.code.inspect}."
+        exit
+      end
+      open(temp_zip_file, 'w') do |io|
+        response.read_body do |chunk|
+          io.write(chunk)
+        end
+      end
+    end
+    puts "Download completed."
+    kept_files = File.read(File.join(speedscope_dir, '.kept-files')).split("\n").reject { |n| n.strip.start_with?('//') }
+    puts "Deleting existing speedscope files..."
+    Dir.foreach(speedscope_dir) do |name|
+      next if name == '.' || name == '..'
+      next if kept_files.include?(name)
+      full_path = File.join(speedscope_dir, name)
+      File.delete(full_path)
+      msg = "Deleted #{full_path}"
+      puts msg.rjust(msg.size + 4, ' ')
+    end
+    puts "Extracting zip files..."
+    Zip::File.open(temp_zip_file) do |zip_file|
+      zip_file.each do |entry|
+        next if !entry.name.start_with?('speedscope/')
+        next if entry.name =~ /perf-vertx-stacks/
+        next if entry.name =~ /README/
+        dest_path = File.join(File.dirname(speedscope_dir), entry.name)
+        entry.extract(dest_path)
+        msg = "Extracted #{entry.name} to #{dest_path}"
+      end
+    end
+    new_version = File.read(File.join(speedscope_dir, 'release.txt')).split("\n")[0].split("@")[-1]
+    if new_version != latest_version
+      puts "ERROR: Something went wrong. Expected the zip file to contain release #{latest_version.inspect}, "\
+           "but instead it contained #{new_version.inspect}. You'll need to investigate what went wrong."
+      exit
+    end
+    puts "Replacing Google Fonts stylesheet URL with the URL of the local copy in index.html..."
+    index_html_content = File.read(File.join(speedscope_dir, 'index.html'))
+    index_html_content.sub!('https://fonts.googleapis.com/css?family=Source+Code+Pro', 'fonts/source-code-pro-regular.css')
+    File.write(File.join(speedscope_dir, 'index.html'), index_html_content)
+    puts "All done!"
+  end
+end
diff --git a/lib/html/speedscope/.kept-files b/lib/html/speedscope/.kept-files
new file mode 100644
index 0000000..eacec63
--- /dev/null
+++ b/lib/html/speedscope/.kept-files
@@ -0,0 +1,6 @@
+// the speedscope_upgrade rake task upgrades the speedscope files
+// in this directory. This file marks which files in this directory
+// that should not be deleted by an upgrade.
+fonts
+README.md
+.kept-files
diff --git a/lib/html/speedscope/README.md b/lib/html/speedscope/README.md
index 1465665..e940854 100644
--- a/lib/html/speedscope/README.md
+++ b/lib/html/speedscope/README.md
@@ -1,3 +1,3 @@
-This directory contains the necessary files and assets to run [speedscope](https://github.com/jlfwong/speedscope). If you wish to update speedscope to a new version, head over to the [releases](https://github.com/jlfwong/speedscope/releases) page on Github, download the `.zip` file of the release you want to upgrade to and unzip it right here inside this directory. Be sure to delete the `perf-vertx-stacks-01-collapsed-all.*.txt` and `README` files that are in the `.zip` file after you unzip it.
+This directory contains the necessary files and assets to run [speedscope](https://github.com/jlfwong/speedscope). The files come from a ZIP file that can be downloaded from the releases page of the speedscope repository on GitHub. If you wish to upgrade speedscope to the latest version, run `bundle exec rake speedscope_upgrade` in the root directory of this repository.
-We're currently on version 1.12.1 of speedscope.
+The rake task will download the ZIP file of the latest speedscope release from Github, remove the old files from the `lib/html/speedscope` directory and extract the ZIP file into the same directory. It will also make a small change to the `index.html` file to replace a link to a Google Fonts stylesheet with a link to a local copy in the `fonts` directory. This is done to make sure speedscope doesn't load any assets from third-parties so that it can work when you're on an intranet.
diff --git a/lib/html/speedscope/fonts/source-code-pro-regular.css b/lib/html/speedscope/fonts/source-code-pro-regular.css
index 0000000..1221532
--- /dev/null
+++ b/lib/html/speedscope/fonts/source-code-pro-regular.css
@@ -0,0 +1,8 @@
+@font-face {
+  font-family: 'Source Code Pro';
+  font-style: normal;
+  font-weight: 400;
+  src: local(''),
+       url('./source-code-pro-v13-regular.woff2') format('woff2'), /* Chrome 26+, Opera 23+, Firefox 39+ */
+       url('./source-code-pro-v13-regular.woff') format('woff'); /* Chrome 6+, Firefox 3.6+, IE 9+, Safari 5.1+ */
diff --git a/lib/html/speedscope/fonts/source-code-pro-v13-regular.woff b/lib/html/speedscope/fonts/source-code-pro-v13-regular.woff
index 0000000..be7e3ee
Binary files /dev/null and b/lib/html/speedscope/fonts/source-code-pro-v13-regular.woff differ
diff --git a/lib/html/speedscope/fonts/source-code-pro-v13-regular.woff2 b/lib/html/speedscope/fonts/source-code-pro-v13-regular.woff2
index 0000000..2198203
Binary files /dev/null and b/lib/html/speedscope/fonts/source-code-pro-v13-regular.woff2 differ
diff --git a/lib/html/speedscope/index.html b/lib/html/speedscope/index.html
index 2dc5ee4..28fc0c5 100644
GitHub sha: c7742152
This commit appears in #478 which was merged by SamSaffron.
