DEV: Add select-kit helper isDisabled (#12827)
In a qunit test for a plugin I need to be able to check if a select-kit element is disabled or not. Adding this helper in core allows me to do that.
diff --git a/app/assets/javascripts/discourse/tests/helpers/select-kit-helper.js b/app/assets/javascripts/discourse/tests/helpers/select-kit-helper.js
index 87cb47c..9632ad6 100644
--- a/app/assets/javascripts/discourse/tests/helpers/select-kit-helper.js
+++ b/app/assets/javascripts/discourse/tests/helpers/select-kit-helper.js
@@ -211,6 +211,10 @@ export default function selectKit(selector) {
       return queryAll(selector).hasClass("is-hidden");
+    isDisabled() {
+      return queryAll(selector).hasClass("is-disabled");
     header() {
       return headerHelper(queryAll(selector).find(".select-kit-header"));
GitHub sha: 0f3b5387
This commit appears in #12827 which was approved by CvX. It was merged by blake.
