DEV: Add simple digest for core stylesheets
And move fonts + category_backgrounds to color definitions stylesheet. This will let us use the same core + plugin stylesheets in multisite.
diff --git a/lib/stylesheet/compiler.rb b/lib/stylesheet/compiler.rb
index efc4718..72231f4 100644
--- a/lib/stylesheet/compiler.rb
+++ b/lib/stylesheet/compiler.rb
@@ -29,9 +29,6 @@ module Stylesheet
         file += File.read path
         case asset.to_s
-        when "desktop", "mobile"
-          file += importer.category_backgrounds
-          file += importer.font
         when "embed", "publish"
         when "wizard"
@@ -39,6 +36,8 @@ module Stylesheet
         when Stylesheet::Manager::COLOR_SCHEME_STYLESHEET
           file += importer.import_color_definitions
           file += importer.import_wcag_overrides
+          file += importer.category_backgrounds
+          file += importer.font
diff --git a/lib/stylesheet/manager/builder.rb b/lib/stylesheet/manager/builder.rb
index 1265c28..dcd223d 100644
--- a/lib/stylesheet/manager/builder.rb
+++ b/lib/stylesheet/manager/builder.rb
@@ -137,6 +137,10 @@ class Stylesheet::Manager::Builder
     !!(@target.to_s =~ Stylesheet::Manager::THEME_REGEX)
+  def is_color_scheme?
+    !!(@target.to_s == Stylesheet::Manager::COLOR_SCHEME_STYLESHEET)
+  end
   def scheme_slug
     Slug.for(ActiveSupport::Inflector.transliterate(@color_scheme.name), 'scheme')
@@ -146,8 +150,10 @@ class Stylesheet::Manager::Builder
     @digest ||= begin
       if is_theme?
         theme_digest
-      else
+      elsif is_color_scheme?
         color_scheme_digest
+      else
+        default_digest
@@ -171,7 +177,7 @@ class Stylesheet::Manager::Builder
   def theme_digest
-    Digest::SHA1.hexdigest(scss_digest.to_s + color_scheme_digest.to_s + settings_digest + plugins_digest + uploads_digest)
+    Digest::SHA1.hexdigest(scss_digest.to_s + color_scheme_digest.to_s + settings_digest + uploads_digest)
   # this protects us from situations where new versions of a plugin removed a file
@@ -218,6 +224,10 @@ class Stylesheet::Manager::Builder
     Digest::SHA1.hexdigest(sha1s.sort!.join("\n"))
+  def default_digest
+    Digest::SHA1.hexdigest "default-#{Stylesheet::Manager.last_file_updated}-#{plugins_digest}"
+  end
   def color_scheme_digest
     cs = @color_scheme || theme&.color_scheme
diff --git a/spec/components/stylesheet/importer_spec.rb b/spec/components/stylesheet/importer_spec.rb
index 4e9a0f8..605b906 100644
--- a/spec/components/stylesheet/importer_spec.rb
+++ b/spec/components/stylesheet/importer_spec.rb
@@ -11,19 +11,16 @@ describe Stylesheet::Importer do
   context "#category_backgrounds" do
     it "applies CDN to background category images" do
-      expect(compile_css("mobile")).to_not include("body.category-")
-      expect(compile_css("desktop")).to_not include("body.category-")
+      expect(compile_css("color_definitions")).to_not include("body.category-")
       background = Fabricate(:upload)
       parent_category = Fabricate(:category)
       category = Fabricate(:category, parent_category_id: parent_category.id, uploaded_background: background)
-      expect(compile_css("mobile")).to include("body.category-#{parent_category.slug}-#{category.slug}{background-image:url(#{background.url})}")
-      expect(compile_css("desktop")).to include("body.category-#{parent_category.slug}-#{category.slug}{background-image:url(#{background.url})}")
+      expect(compile_css("color_definitions")).to include("body.category-#{parent_category.slug}-#{category.slug}{background-image:url(#{background.url})}")
       GlobalSetting.stubs(:cdn_url).returns("//awesome.cdn")
-      expect(compile_css("mobile")).to include("body.category-#{parent_category.slug}-#{category.slug}{background-image:url(//awesome.cdn#{background.url})}")
-      expect(compile_css("desktop")).to include("body.category-#{parent_category.slug}-#{category.slug}{background-image:url(//awesome.cdn#{background.url})}")
+      expect(compile_css("color_definitions")).to include("body.category-#{parent_category.slug}-#{category.slug}{background-image:url(//awesome.cdn#{background.url})}")
     it "applies S3 CDN to background category images" do
@@ -36,8 +33,7 @@ describe Stylesheet::Importer do
       background = Fabricate(:upload_s3)
       category = Fabricate(:category, uploaded_background: background)
-      expect(compile_css("mobile")).to include("body.category-#{category.slug}{background-image:url(https://s3.cdn/original")
-      expect(compile_css("desktop")).to include("body.category-#{category.slug}{background-image:url(https://s3.cdn/original")
+      expect(compile_css("color_definitions")).to include("body.category-#{category.slug}{background-image:url(https://s3.cdn/original")
@@ -45,8 +41,7 @@ describe Stylesheet::Importer do
   context "#font" do
     it "includes font variable" do
       default_font = ":root{--font-family: Arial, sans-serif}"
-      expect(compile_css("desktop")).to include(default_font)
-      expect(compile_css("mobile")).to include(default_font)
+      expect(compile_css("color_definitions")).to include(default_font)
       expect(compile_css("embed")).to include(default_font)
       expect(compile_css("publish")).to include(default_font)
@@ -58,14 +53,14 @@ describe Stylesheet::Importer do
       SiteSetting.base_font = base_font[:key]
       SiteSetting.heading_font = heading_font[:key]
         .to include(":root{--font-family: #{base_font[:stack]}}")
         .and include(":root{--heading-font-family: #{heading_font[:stack]}}")
       set_cdn_url("http://cdn.localhost")
       # uses CDN and includes cache-breaking param
         .to include("http://cdn.localhost/fonts/#{base_font[:variants][0][:filename]}?v=#{DiscourseFonts::VERSION}")
         .and include("http://cdn.localhost/fonts/#{heading_font[:variants][0][:filename]}?v=#{DiscourseFonts::VERSION}")
diff --git a/spec/components/stylesheet/manager_spec.rb b/spec/components/stylesheet/manager_spec.rb
index da6768d..1c7673a 100644
--- a/spec/components/stylesheet/manager_spec.rb
+++ b/spec/components/stylesheet/manager_spec.rb
@@ -188,22 +188,12 @@ describe Stylesheet::Manager do
       DiscoursePluginRegistry.reset!
-    it 'can correctly account for plugins in digest' do
-      theme = Fabricate(:theme)
-      manager = manager(theme.id)
-      builder = Stylesheet::Manager::Builder.new(
-        target: :desktop_theme, theme: theme, manager: manager
+    it 'can correctly account for plugins in default digest' do
+      builder = Stylesheet::Manager::Builder.new(target: :desktop, manager: manager)
       digest1 = builder.digest
       DiscoursePluginRegistry.stylesheets["fake"] = Set.new(["fake_file"])
       digest2 = builder.digest
       expect(digest1).not_to eq(digest2)
@@ -282,6 +272,21 @@ describe Stylesheet::Manager do
+    it 'returns different digest based on target' do
+      theme = Fabricate(:theme)
+      builder = Stylesheet::Manager::Builder.new(target: :desktop_theme, theme: theme, manager: manager)
+      expect(builder.digest).to eq(builder.theme_digest)
+      builder = Stylesheet::Manager::Builder.new(target: :color_definitions, manager: manager)
+      expect(builder.digest).to eq(builder.color_scheme_digest)
+      builder = Stylesheet::Manager::Builder.new(target: :admin, manager: manager)
+      expect(builder.digest).to eq(builder.default_digest)
GitHub sha: d82c58e6cc5dd43b8bfb062838a24cac85ac9ca2
This commit appears in #13466 which was approved by tgxworld. It was merged by tgxworld.
