DEV: Add toolbar button when chat in installed (PR #14422)
GitHub
It looks like you are calling a private API here. Is there a way you could make a public API for this?
@eviltrout this is true, but this is modifying the component that those are private to… so technically this should be allowed, right?
Unfortunately not. No plugin should be calling a method with _ – if I see a method with _ I don’t even search our all-the-plugins before changing it. You will need to establish a more public interface for what you are doing.
