DEV: add "WAIT_FOR_URL" env to smoke test
DEV: add “WAIT_FOR_URL” env to smoke test
This allows you to wait up to N seconds for the smoke test url to come up in some cases you want to kick off the smoke test prior to having the smoke test env ready to accept connections
diff --git a/lib/tasks/smoke_test.rake b/lib/tasks/smoke_test.rake
index d8eefa9..57630f6 100644
--- a/lib/tasks/smoke_test.rake
+++ b/lib/tasks/smoke_test.rake
@@ -33,12 +33,31 @@ task "smoke:test" do
   dir = ENV["SMOKE_TEST_SCREENSHOT_PATH"] || 'tmp/smoke-test-screenshots'
   FileUtils.mkdir_p(dir) unless Dir.exists?(dir)
-  response = Net::HTTP.start(uri.hostname, uri.port, use_ssl: uri.scheme == 'https') do |http|
-    http.request(request)
+  wait = ENV["WAIT_FOR_URL"].to_i
+  success = false
+  code = nil
+  retries = 0
+  loop do
+    response = Net::HTTP.start(uri.hostname, uri.port, use_ssl: uri.scheme == 'https') do |http|
+      http.request(request)
+    end
+    success = response.code == "200"
+    code = response.code
+    if !success && wait > 0
+      sleep 5
+      wait -= 5
+      retries += 1
+    else
+      break
+    end
-  if response.code != "200"
-    raise "TRIVIAL GET FAILED WITH #{response.code}"
+  if !success
+    raise "TRIVIAL GET FAILED WITH #{code}: retried #{retries} times"
   results = +""
diff --git a/test/smoke_test.js b/test/smoke_test.js
index 5756332..31f61ab 100644
--- a/test/smoke_test.js
+++ b/test/smoke_test.js
@@ -1,3 +1,5 @@
+/*eslint no-console: "off"*/
 const args = process.argv.slice(2);
 if (args.length < 1 || args.length > 2) {
GitHub sha: 50e6ee55
