DEV: Added support for custom site setting 'emoji_list' (PR #12414)
@jjaffeux
GitHub
I feel like emoji list should be in core itself though ( I mean the component itself). Let me discuss this internally.
That will be a nice thing to have😍
For this to work we will need the setting to accept some parameter “required” emojis, otherwise no one but discourse-reactions can use it
Can you explain which types of parameters?
What I mean is that we need to have the heart always present in the list, but what if another plugin doesn’t need any specific emoji in its setting ?
For this i think we can remove appending likes in the list and add a separate setting in reactions plugin and make this setting simple just for emojis list
@jjaffeux I added the setting in this PR and tried to make it general use do try it out locally
use em here please
did you lose my comment about sharing a shift fn here ?
      value,
can we replace all of this by:
if (!emojiUrlFor(input)) {
  • checking input doesn’t seem necessary, emojiUrlFor will call buildEmojiUrl which does a String(input) so even if null or undefined will return “”
  • we don’t care what input includes, we just need to know if it’s a valid emoji or not
I don’t see the need for this line, just use this.collection directly
what if values is empty? can it be empty ?
why the empty lines here ? it’s all about object setup, you can group it
can we find a better name than object please ?
can we find a better name than res please ?
values are the site-setting value, if it is empty then collection will be empty. and if the collection is empty then there’s no editing of the textbox
I read the comment, but the reason for not doing this was, we can make it a single function but we are doing totally different operations in both of these functions. combining both will reduce the readability of the function IMO. thoughts?
shiftDirection(index, direction) {
    if (direction === "up" && !index) {
      return;
    if (direction === "down" && index === this.collection.length) {
      return;
    const temp = this.collection[index];
    if(direction === "up") {
      this.collection[index] = this.collection[index - 1];
      this.collection[index - 1] = temp;
    } else {
      this.collection[index] = this.collection[index + 1];
      this.collection[index + 1] = temp;
    this._saveValues();
Indeed, ill change this
