DEV: adds PostEvent#is_expired? tests
diff --git a/spec/models/post_event_spec.rb b/spec/models/post_event_spec.rb
new file mode 100644
index 0000000..ca28a32
--- /dev/null
+++ b/spec/models/post_event_spec.rb
@@ -0,0 +1,96 @@
+require 'rails_helper'
+require_relative '../fabricators/post_event_fabricator'
+describe DiscourseCalendar::PostEvent do
+  PostEvent ||= DiscourseCalendar::PostEvent
+  before do
+    freeze_time DateTime.parse('2020-04-24 14:10')
+    Jobs.run_immediately!
+    SiteSetting.post_event_enabled = true
+  end
+  describe '#is_expired?' do
+    context 'has ends_at' do
+      context '&& starts_at < current date' do
+        context '&& ends_at < current date' do
+          it 'is expired' do
+            post_event = PostEvent.new(
+              starts_at: DateTime.parse('2020-04-22 14:05'),
+              ends_at: DateTime.parse('2020-04-23 14:05'),
+            expect(post_event.is_expired?).to be(true)
+          end
+        end
+        context '&& ends_at > current date' do
+          it 'is not expired' do
+              starts_at: DateTime.parse('2020-04-24 14:15'),
+              ends_at: DateTime.parse('2020-04-25 11:05'),
+            expect(post_event.is_expired?).to be(false)
+          end
+        end
+              starts_at: DateTime.parse('2020-04-22 14:15'),
+              ends_at: DateTime.parse('2020-04-23 11:05'),
+          end
+        end
+      end
+      context '&& starts_at > current date' do
+            starts_at: DateTime.parse('2020-04-25 14:05'),
+            ends_at: DateTime.parse('2020-04-26 14:05'),
+        end
+      end
+    end
+    context 'has not ends_at date' do
+            starts_at: DateTime.parse('2020-04-24 14:05')
+        end
+      end
+      context '&& starts_at == current date' do
+            starts_at: DateTime.parse('2020-04-24 14:10')
+        end
+      end
+        end
+      end
+    end
+  end
+end
GitHub sha: a9821f9e
