DEV: allow `dev:populate` rake task in production environment. (#13777)
DEV: allow dev:populate rake task in production environment. (#13777)
To use this rake task in production ALLOW_DEV_POPULATE environment variable should be set to “1”.
diff --git a/Gemfile b/Gemfile
index 80d2644..efd3fd5 100644
--- a/Gemfile
+++ b/Gemfile
@@ -175,8 +175,16 @@ group :development do
   gem 'better_errors', platform: :mri, require: !!ENV['BETTER_ERRORS']
   gem 'binding_of_caller'
   gem 'yaml-lint'
+end
+if ENV["ALLOW_DEV_POPULATE"] == "1"
   gem 'discourse_dev_assets'
   gem 'faker', "~> 2.16"
+else
+  group :development do
+    gem 'discourse_dev_assets'
+    gem 'faker', "~> 2.16"
+  end
 # this is an optional gem, it provides a high performance replacement
diff --git a/lib/discourse.rb b/lib/discourse.rb
index dd6b65e..1d20365 100644
--- a/lib/discourse.rb
+++ b/lib/discourse.rb
@@ -1003,6 +1003,10 @@ module Discourse
     headers['Access-Control-Allow-Methods'] = CDN_REQUEST_METHODS.join(", ")
     headers
+  def self.allow_dev_populate?
+    Rails.env.development? || ENV["ALLOW_DEV_POPULATE"] == "1"
+  end
 # rubocop:enable Style/GlobalVars
diff --git a/lib/discourse_dev/record.rb b/lib/discourse_dev/record.rb
index b8b07d2..6a57189 100644
--- a/lib/discourse_dev/record.rb
+++ b/lib/discourse_dev/record.rb
@@ -30,6 +30,10 @@ module DiscourseDev
     def populate!(ignore_current_count: false)
+      unless Discourse.allow_dev_populate?
+        raise 'To run this rake task in a production site, set the value of `ALLOW_DEV_POPULATE` environment variable to "1"'
+      end
       unless ignore_current_count
         if current_count >= @count
           puts "Already have #{current_count} #{type} records"
diff --git a/lib/freedom_patches/translate_accelerator.rb b/lib/freedom_patches/translate_accelerator.rb
index 2bc4cac..7bf8988 100644
--- a/lib/freedom_patches/translate_accelerator.rb
+++ b/lib/freedom_patches/translate_accelerator.rb
@@ -55,7 +55,7 @@ module I18n
         # load it
         I18n.backend.load_translations(I18n.load_path.grep(/\.#{Regexp.escape locale}\.yml$/))
-        if Rails.env.development?
+        if Discourse.allow_dev_populate?
           I18n.backend.load_translations(I18n.load_path.grep(/.*faker.*\/#{Regexp.escape locale}\.yml$/))
           I18n.backend.load_translations(I18n.load_path.grep(/.*faker.*\/#{Regexp.escape locale}\/.*\.yml$/))
GitHub sha: 08c6a7679d8f74e5b63df167c179388bd9e3e43f
This commit appears in #13777 which was approved by eviltrout. It was merged by vinothkannans.
