DEV: allow to have duplicate topic titles if categegory is different (#10034)
Co-authored-by: Robin Ward robin.ward@gmail.com
diff --git a/app/models/topic.rb b/app/models/topic.rb
index 49d14cb..a269988 100644
--- a/app/models/topic.rb
+++ b/app/models/topic.rb
@@ -155,7 +155,12 @@ class Topic < ActiveRecord::Base
                                     message: :has_already_been_used,
                                     allow_blank: true,
                                     case_sensitive: false,
-                                    collection: Proc.new { Topic.listable_topics } }
+                                    collection: Proc.new { |t|
+                                      SiteSetting.allow_duplicate_topic_titles_category? ?
+                                        Topic.listable_topics.where("category_id = ?", t.category_id) :
   validates :category_id,
             presence: true,
diff --git a/config/locales/server.en.yml b/config/locales/server.en.yml
index 5d79648..5a3bc5a 100644
--- a/config/locales/server.en.yml
+++ b/config/locales/server.en.yml
@@ -1449,6 +1449,7 @@ en:
     category_search_priority_very_high_weight: "Weight applied to ranking for very high category search priority."
     allow_uncategorized_topics: "Allow topics to be created without a category. WARNING: If there are any uncategorized topics, you must recategorize them before turning this off."
     allow_duplicate_topic_titles: "Allow topics with identical, duplicate titles."
+    allow_duplicate_topic_titles_category: "Allow topics with identical, duplicate titles if the category is different. allow_duplicate_topic_titles must be false."
     unique_posts_mins: "How many minutes before a user can make a post with the same content again"
     educate_until_posts: "When the user starts typing their first (n) new posts, show the pop-up new user education panel in the composer."
     title: "The name of this site, as used in the title tag."
diff --git a/config/site_settings.yml b/config/site_settings.yml
index 2948b87..502d71c 100644
--- a/config/site_settings.yml
+++ b/config/site_settings.yml
@@ -716,6 +716,7 @@ posting:
     default: true
     refresh: true
   allow_duplicate_topic_titles: false
+  allow_duplicate_topic_titles_category: false
   min_title_similar_length:
     client: true
     default: 10
diff --git a/lib/validators/unique_among_validator.rb b/lib/validators/unique_among_validator.rb
index 82fed5c..ed3d142 100644
--- a/lib/validators/unique_among_validator.rb
+++ b/lib/validators/unique_among_validator.rb
@@ -12,7 +12,7 @@ class UniqueAmongValidator < ActiveRecord::Validations::UniquenessValidator
     # do nothing further unless there were some duplicates.
     unless new_errors == 0
       # now look only in the collection we care about.
-      dupes = options[:collection].call.where("lower(#{attribute}) = ?", value.downcase)
+      dupes = options[:collection].call(record).where("lower(#{attribute}) = ?", value.downcase)
       dupes = dupes.where("id != ?", record.id) if record.persisted?
       # pop off the error, if it was a false positive
diff --git a/script/import_scripts/base.rb b/script/import_scripts/base.rb
index a42b8c3..64de94b 100644
--- a/script/import_scripts/base.rb
+++ b/script/import_scripts/base.rb
@@ -77,6 +77,7 @@ class ImportScripts::Base
       min_personal_message_post_length: 1,
       min_personal_message_title_length: 1,
       allow_duplicate_topic_titles: true,
+      allow_duplicate_topic_titles_category: false,
       disable_emails: 'yes',
       max_attachment_size_kb: 102400,
       max_image_size_kb: 102400,
diff --git a/spec/models/topic_spec.rb b/spec/models/topic_spec.rb
index d1d5d1c..ead9621 100644
--- a/spec/models/topic_spec.rb
+++ b/spec/models/topic_spec.rb
@@ -255,19 +255,27 @@ describe Topic do
   context 'topic title uniqueness' do
+    let!(:category1) { Fabricate(:category) }
+    let!(:category2) { Fabricate(:category) }
-    let!(:topic) { Fabricate(:topic) }
-    let(:new_topic) { Fabricate.build(:topic, title: topic.title) }
+    let!(:topic) { Fabricate(:topic, category: category1) }
+    let(:new_topic) { Fabricate.build(:topic, title: topic.title, category: category1) }
+    let(:new_topic_different_cat) { Fabricate.build(:topic, title: topic.title, category: category2) }
     context "when duplicates aren't allowed" do
       before do
-        SiteSetting.expects(:allow_duplicate_topic_titles?).returns(false)
+        SiteSetting.allow_duplicate_topic_titles = false
+        SiteSetting.allow_duplicate_topic_titles_category = false
       it "won't allow another topic to be created with the same name" do
         expect(new_topic).not_to be_valid
+      it "won't even allow another topic to be created with the same name but different category" do
+        expect(new_topic_different_cat).not_to be_valid
+      end
       it "won't allow another topic with an upper case title to be created" do
         new_topic.title = new_topic.title.upcase
@@ -286,7 +294,8 @@ describe Topic do
     context "when duplicates are allowed" do
       before do
-        SiteSetting.expects(:allow_duplicate_topic_titles?).returns(true)
+        SiteSetting.allow_duplicate_topic_titles = true
       it "will allow another topic to be created with the same name" do
@@ -294,6 +303,21 @@ describe Topic do
+    context "when duplicates are allowed if the category is different" do
+      before do
+        SiteSetting.allow_duplicate_topic_titles_category = true
+      end
+      it "will allow another topic to be created with the same name but different category" do
+        expect(new_topic_different_cat).to be_valid
+      end
+      it "won't allow another topic to be created with the same name in same category" do
+        expect(new_topic).not_to be_valid
+      end
+    end
   context 'html in title' do
GitHub sha: e3147158
This commit appears in #10034 which was approved by eviltrout. It was merged by eviltrout.
