DEV: allow USR2 to restart unicorn in dev
Well all this does is amends a commit comment cause I was over eager and pushed previous commit.
This is the comment I wanted…
This allows pkill -USR2 -f 'ruby bin/unicorn' to restart current unicorn
It is handy if you want to bind a keyboard shortcut for unicorn restarts in dev.
By doing so you can avoid finding the terminal, hitting ctrl-c and then hitting up, enter, heading back to browser.
It saves time.
Automate stuff, you will not regret it…
diff --git a/bin/unicorn b/bin/unicorn
index 01b9002..865e8d8 100755
--- a/bin/unicorn
+++ b/bin/unicorn
@@ -50,10 +50,9 @@ if ARGV.include?("--help")
   exit
-# this dev_mode hackery enables, the following script to be used to restart unicorn:
+# this dev_mode hackery enables, the following to be used to restart unicorn:
-# #!/usr/bin/env bash
-# kill -s USR2 `ps aux | grep ruby\ bin\/unicorn | grep -v grep | awk '{print $2}'`
+# pkill -USR2 -f 'ruby bin/unicorn'
 # This is handy if you want to bind a key to restarting unicorn in dev
GitHub sha: 7c084c7c
