DEV: allows lodash to be updated with `rake javascript:update` (#7881)
DEV: allows lodash to be updated with rake javascript:update (#7881)
diff --git a/lib/tasks/javascript.rake b/lib/tasks/javascript.rake
index 0fcc37b..f933c4b 100644
--- a/lib/tasks/javascript.rake
+++ b/lib/tasks/javascript.rake
@@ -78,6 +78,9 @@ task 'javascript:update' do
       source: 'moment-timezone/builds/moment-timezone-with-data-10-year-range.js',
       destination: 'moment-timezone-with-data.js'
+      source: 'lodash.js',
+      destination: 'lodash.js'
       source: 'moment-timezone-names-translations/locales/.',
       destination: 'moment-timezone-names-locale'
@@ -124,6 +127,12 @@ task 'javascript:update' do
       dest = "#{vendor_js}/#{filename}"
+    # lodash.js needs building
+    if src.include? "lodash.js"
+      puts "Building custom lodash.js build"
+      system('yarn run lodash include="each,filter,map,range,first,isEmpty,chain,extend,every,omit,merge,union,sortBy,uniq,intersection,reject,compact,reduce,debounce,throttle,values,pick,keys,flatten,min,max,isArray,delay,isString,isEqual,without,invoke,clone,findIndex,find,groupBy" minus="template" -d -o "node_modules/lodash.js"')
+    end
     unless File.exists?(dest)
       STDERR.puts "New dependency added: #{dest}"
diff --git a/package.json b/package.json
index 7658ee5..5f3b0e7 100644
--- a/package.json
+++ b/package.json
@@ -43,7 +43,8 @@
     "puppeteer": "1.16",
     "qunit": "2.8.0",
     "route-recognizer": "^0.3.3",
-    "sinon": "^7.2.5"
+    "sinon": "^7.2.5",
+    "lodash-cli": "^4"
   "scripts": {
     "preinstall": "node -e \"if(process.env.npm_execpath.indexOf('yarn') === -1) throw new Error('NPM is not supported, please use Yarn instead. ')\""
diff --git a/yarn.lock b/yarn.lock
index 65b2839..a4d8585 100644
--- a/yarn.lock
+++ b/yarn.lock
@@ -190,6 +190,15 @@ ajv@^5.2.3, ajv@^5.3.0:
     fast-json-stable-stringify "^2.0.0"
     json-schema-traverse "^0.3.0"
+align-text@^0.1.1, align-text@^0.1.3:
+  version "0.1.4"
+  resolved "https://registry.yarnpkg.com/align-text/-/align-text-0.1.4.tgz#0cd90a561093f35d0a99256c22b7069433fad117"
+  integrity sha1-DNkKVhCT810KmSVsIrcGlDP60Rc=
+  dependencies:
+    kind-of "^3.0.2"
+    longest "^1.0.1"
+    repeat-string "^1.5.2"
 ansi-escapes@^3.0.0:
   version "3.1.0"
   resolved "https://registry.yarnpkg.com/ansi-escapes/-/ansi-escapes-3.1.0.tgz#f73207bb81207d75fd6c83f125af26eea378ca30"
@@ -267,6 +276,11 @@ async-limiter@~1.0.0:
   resolved "https://registry.yarnpkg.com/async-limiter/-/async-limiter-1.0.0.tgz#78faed8c3d074ab81f22b4e985d79e8738f720f8"
   integrity sha512-jp/uFnooOiO+L211eZOoSyzpOITMXx1rBITauYykG3BRYPu8h0UcxsPNB04RR5vo4Tyz3+ay17tR6JVf9qzYWg==
+async@~0.2.6:
+  version "0.2.10"
+  resolved "https://registry.yarnpkg.com/async/-/async-0.2.10.tgz#b6bbe0b0674b9d719708ca38de8c237cb526c3d1"
+  integrity sha1-trvgsGdLnXGXCMo43owjfLUmw9E=
 atob@^2.1.1:
   version "2.1.2"
   resolved "https://registry.yarnpkg.com/atob/-/atob-2.1.2.tgz#6d9517eb9e030d2436666651e86bd9f6f13533c9"
@@ -389,6 +403,11 @@ callsites@^0.2.0:
   resolved "https://registry.yarnpkg.com/callsites/-/callsites-0.2.0.tgz#afab96262910a7f33c19a5775825c69f34e350ca"
   integrity sha1-r6uWJikQp/M8GaV3WCXGnzTjUMo=
+camelcase@^1.0.2:
+  version "1.2.1"
+  resolved "https://registry.yarnpkg.com/camelcase/-/camelcase-1.2.1.tgz#9bb5304d2e0b56698b2c758b08a3eaa9daa58a39"
+  integrity sha1-m7UwTS4LVmmLLHWLCKPqqdqlijk=
 capture-exit@^1.2.0:
   version "1.2.0"
   resolved "https://registry.yarnpkg.com/capture-exit/-/capture-exit-1.2.0.tgz#1c5fcc489fd0ab00d4f1ac7ae1072e3173fbab6f"
@@ -396,6 +415,14 @@ capture-exit@^1.2.0:
   dependencies:
     rsvp "^3.3.3"
+center-align@^0.1.1:
+  version "0.1.3"
+  resolved "https://registry.yarnpkg.com/center-align/-/center-align-0.1.3.tgz#aa0d32629b6ee972200411cbd4461c907bc2b7ad"
+  integrity sha1-qg0yYptu6XIgBBHL1EYckHvCt60=
+  dependencies:
+    align-text "^0.1.3"
+    lazy-cache "^1.0.3"
 chalk@^1.1.3:
   version "1.1.3"
   resolved "https://registry.yarnpkg.com/chalk/-/chalk-1.1.3.tgz#a8115c55e4a702fe4d150abd3872822a7e09fc98"
@@ -493,6 +520,22 @@ cli-width@^2.0.0:
   resolved "https://registry.yarnpkg.com/cli-width/-/cli-width-2.2.0.tgz#ff19ede8a9a5e579324147b0c11f0fbcbabed639"
   integrity sha1-/xnt6Kml5XkyQUewwR8PvLq+1jk=
+cliui@^2.1.0:
+  version "2.1.0"
+  resolved "https://registry.yarnpkg.com/cliui/-/cliui-2.1.0.tgz#4b475760ff80264c762c3a1719032e91c7fea0d1"
+  integrity sha1-S0dXYP+AJkx2LDoXGQMukcf+oNE=
+  dependencies:
+    center-align "^0.1.1"
+    right-align "^0.1.1"
+    wordwrap "0.0.2"
+closure-compiler@0.2.12:
+  version "0.2.12"
+  resolved "https://registry.yarnpkg.com/closure-compiler/-/closure-compiler-0.2.12.tgz#6c3087cad12742c79e47f0ce50e87af91cf8e171"
+  integrity sha1-bDCHytEnQseeR/DOUOh6+Rz44XE=
+  dependencies:
+    google-closure-compiler "20150901.x"
 co@^4.6.0:
   version "4.6.0"
   resolved "https://registry.yarnpkg.com/co/-/co-4.6.0.tgz#6ea6bdf3d853ae54ccb8e47bfa0bf3f9031fb184"
@@ -614,6 +657,11 @@ debug@^4.1.0:
   dependencies:
     ms "^2.1.1"
+decamelize@^1.0.0:
+  version "1.2.0"
+  resolved "https://registry.yarnpkg.com/decamelize/-/decamelize-1.2.0.tgz#f6534d15148269b20352e7bee26f501f9a191290"
+  integrity sha1-9lNNFRSCabIDUue+4m9QH5oZEpA=
 decode-uri-component@^0.2.0:
   version "0.2.0"
   resolved "https://registry.yarnpkg.com/decode-uri-component/-/decode-uri-component-0.2.0.tgz#eb3913333458775cb84cd1a1fae062106bb87545"
@@ -1014,6 +1062,18 @@ get-value@^2.0.3, get-value@^2.0.6:
   resolved "https://registry.yarnpkg.com/get-value/-/get-value-2.0.6.tgz#dc15ca1c672387ca76bd37ac0a395ba2042a2c28"
   integrity sha1-3BXKHGcjh8p2vTesCjlbogQqLCg=
+glob@7.1.1:
+  version "7.1.1"
+  resolved "https://registry.yarnpkg.com/glob/-/glob-7.1.1.tgz#805211df04faaf1c63a3600306cdf5ade50b2ec8"
+  integrity sha1-gFIR3wT6rxxjo2ADBs31reULLsg=
+  dependencies:
+    fs.realpath "^1.0.0"
+    inflight "^1.0.4"
+    inherits "2"
+    minimatch "^3.0.2"
+    once "^1.3.0"
+    path-is-absolute "^1.0.0"
 glob@^7.0.5, glob@^7.1.2:
   version "7.1.3"
   resolved "https://registry.yarnpkg.com/glob/-/glob-7.1.3.tgz#3960832d3f1574108342dafd3a67b332c0969df1"
@@ -1051,6 +1111,11 @@ globals@^11.0.1, globals@^11.1.0:
   resolved "https://registry.yarnpkg.com/globals/-/globals-11.9.0.tgz#bde236808e987f290768a93d065060d78e6ab249"
   integrity sha512-5cJVtyXWH8PiJPVLZzzoIizXx944O4OmRro5MWKx5fT4MgcN7OfaMutPeaTdJCCURwbWdhhcCWcKIffPnmTzBg==
+google-closure-compiler@20150901.x:
+  version "20150901.0.0"
+  resolved "https://registry.yarnpkg.com/google-closure-compiler/-/google-closure-compiler-20150901.0.0.tgz#3d01c6cade65790a9bfb4e30b2158b7635acbade"
+  integrity sha1-PQHGyt5leQqb+04wshWLdjWsut4=
 graceful-fs@^4.1.2:
   version "4.1.15"
   resolved "https://registry.yarnpkg.com/graceful-fs/-/graceful-fs-4.1.15.tgz#ffb703e1066e8a0eeaa4c8b80ba9253eeefbfb00"
@@ -1441,6 +1506,11 @@ kind-of@^6.0.0, kind-of@^6.0.2:
   resolved "https://registry.yarnpkg.com/kind-of/-/kind-of-6.0.2.tgz#01146b36a6218e64e58f3a8d66de5d7fc6f6d051"
   integrity sha512-s5kLOcnH0XqDO+FvuaLX8DDjZ18CGFk7VygH40QoKPUQhW4e2rvM0rwUq0t8IQDOwYSeLK01U90OjzBTme2QqA==
+lazy-cache@^1.0.3:
+  version "1.0.4"
+  resolved "https://registry.yarnpkg.com/lazy-cache/-/lazy-cache-1.0.4.tgz#a1d78fc3a50474cb80845d3b3b6e1da49a446e8e"
+  integrity sha1-odePw6UEdMuAhF07O24dpJpEbo4=
 levn@^0.3.0, levn@~0.3.0:
   version "0.3.0"
   resolved "https://registry.yarnpkg.com/levn/-/levn-0.3.0.tgz#3b09924edf9f083c0490fdd4c0bc4421e04764ee"
@@ -1464,6 +1534,22 @@ linkify-it@^2.0.0:
   dependencies:
     uc.micro "^1.0.1"
+lodash-cli@^4:
+  version "4.17.5"
+  resolved "https://registry.yarnpkg.com/lodash-cli/-/lodash-cli-4.17.5.tgz#1bab72c8c9980febf4fe7a1900b0971ce040dd0b"
+  integrity sha512-eeQi+oVS76ofP791g4wEGs4B4nyc4fiHboUCc0BzM8qCkLAzqbroewOt98A8ISoY1HH2di00pENNErXf0MWxiw==
+  dependencies:
+    closure-compiler "0.2.12"
+    glob "7.1.1"
+    lodash "4.17.5"
+    semver "5.3.0"
+    uglify-js "2.7.5"
+lodash@4.17.5:
+  version "4.17.5"
GitHub sha: 550e8116
I ran this locally, and it installed lodash 4.17.5, because the latest release of lodash-cli published in NPM/Yarn is 4.17.5 from a year ago.
We need to switch to the Github url in package.json:
"lodash-cli": "https://github.com/lodash-archive/lodash-cli",
Also, the version in vendors/ is still at 4.17.11, we need to commit the updated lodash build.
(Happy to follow-up here if you’re done for the day @jjaffeux.)
Hey, yes I figured at the same time, sorry didnt see your post before, but I guess you have seen Ive made a commit to fix this.
