DEV: allows smoke test to run on macOS (#7735)
diff --git a/lib/tasks/smoke_test.rake b/lib/tasks/smoke_test.rake
index 57630f6..70abebc 100644
--- a/lib/tasks/smoke_test.rake
+++ b/lib/tasks/smoke_test.rake
@@ -2,12 +2,18 @@
 desc "run chrome headless smoke tests on current build"
 task "smoke:test" do
-  unless system("command -v google-chrome >/dev/null;")
+  if RbConfig::CONFIG['host_os'][/darwin|mac os/]
+    google_chrome_cli = "/Applications/Google\ Chrome.app/Contents/MacOS/Google\ Chrome"
+  else
+    google_chrome_cli = "google-chrome"
+  end
+  unless system("command -v \"#{google_chrome_cli}\" >/dev/null")
     abort "Chrome is not installed. Download from https://www.google.com/chrome/browser/desktop/index.html"
-  if Gem::Version.new(`$(command -v google-chrome) --version`.match(/[\d\.]+/)[0]) < Gem::Version.new("59")
-    abort "Chrome 59 or higher is required to run smoke tests in headless mode."
+  if Gem::Version.new(`\"#{google_chrome_cli}\" --version`.match(/[\d\.]+/)[0]) < Gem::Version.new("59")
+    abort "Chrome 59 or higher is required to run tests in headless mode."
   system("yarn install --dev")
GitHub sha: 8cd13b22
:+1:
