DEV: allows to call a widget function without re-rendering the widget (PR #10004)
GitHub
Shouldn’t this method use the new callWidgetFunction?
Yes, maybe… In one hand you DRY on the other hand you avoid some indirection of if call had found a widget then return else… Not sure it’s very worth it.
I made the change :man_artist:
