DEV: apply coding standards (#12)
diff --git a/.eslintrc b/.eslintrc
new file mode 100644
index 0000000..7898fbf
--- /dev/null
+++ b/.eslintrc
@@ -0,0 +1,3 @@
+  "extends": "eslint-config-discourse"
diff --git a/.gitignore b/.gitignore
index e69de29..2d83702 100644
--- a/.gitignore
+++ b/.gitignore
@@ -0,0 +1,3 @@
+node_modules
+yarn-error.log
+.rubocop-https---raw-githubusercontent-com-discourse-*
diff --git a/.template-lintrc.js b/.template-lintrc.js
index 0000000..a558b8e
--- /dev/null
+++ b/.template-lintrc.js
@@ -0,0 +1,4 @@
+module.exports = {
+  plugins: ["ember-template-lint-plugin-discourse"],
+  extends: "discourse:recommended",
diff --git a/assets/javascripts/discourse-markdown/discourse-graphviz.js.es6 b/assets/javascripts/discourse-markdown/discourse-graphviz.js.es6
index ae0facd..cbab544 100644
--- a/assets/javascripts/discourse-markdown/discourse-graphviz.js.es6
+++ b/assets/javascripts/discourse-markdown/discourse-graphviz.js.es6
@@ -6,14 +6,14 @@ export function setup(helper) {
   helper.whiteList([
     "div.graphviz",
     "div.graphviz.is-loading",
-    "div.graphviz-svg"
+    "div.graphviz-svg",
   helper.registerOptions((opts, siteSettings) => {
     opts.features.graphviz = siteSettings.discourse_graphviz_enabled;
-  helper.registerPlugin(md => {
+  helper.registerPlugin((md) => {
     if (md.options.discourse.features.graphviz) {
       md.block.bbcode.ruler.push("graphviz", {
         tag: "graphviz",
@@ -38,7 +38,7 @@ export function setup(helper) {
           token.content = `<div class="graphviz is-loading${svgOnly}" ${engine}>\n${escaped}\n</div>\n`;
           return true;
diff --git a/assets/javascripts/initializers/discourse-graphviz.js.es6 b/assets/javascripts/initializers/discourse-graphviz.js.es6
index 7c5f931..8dd0ad3 100644
--- a/assets/javascripts/initializers/discourse-graphviz.js.es6
+++ b/assets/javascripts/initializers/discourse-graphviz.js.es6
@@ -33,7 +33,7 @@ export default {
           /* global vizRenderStringSync */
           const svgChart = vizRenderStringSync(graphDefinition, {
             format: "svg",
-            engine
+            engine,
           $container.html(svgChart);
         } catch (e) {
@@ -50,9 +50,9 @@ export default {
     const siteSettings = container.lookup("site-settings:main");
     if (siteSettings.discourse_graphviz_enabled) {
-      withPluginApi("0.8.22", api => {
+      withPluginApi("0.8.22", (api) => {
         api.decorateCooked(
-          $elem => {
+          ($elem) => {
             const $graphviz = $elem.find(".graphviz");
             if ($graphviz.length) {
               run.debounce(this, this.renderGraphs, $graphviz, 200);
@@ -62,5 +62,5 @@ export default {
diff --git a/package.json b/package.json
index 0000000..9df2b90
--- /dev/null
+++ b/package.json
@@ -0,0 +1,7 @@
+  "author": "Discourse",
+  "license": "MIT",
+  "devDependencies": {
+    "eslint-config-discourse": "latest"
diff --git a/yarn.lock b/yarn.lock
index 0000000..aece863
--- /dev/null
+++ b/yarn.lock
@@ -0,0 +1,1595 @@
+# THIS IS AN AUTOGENERATED FILE. DO NOT EDIT THIS FILE DIRECTLY.
+# yarn lockfile v1
+"@babel/code-frame@^7.0.0", "@babel/code-frame@^7.10.4":
+  version "7.10.4"
+  resolved "https://registry.yarnpkg.com/@babel/code-frame/-/code-frame-7.10.4.tgz#168da1a36e90da68ae8d49c0f1b48c7c6249213a"
+  integrity sha512-vG6SvB6oYEhvgisZNFRmRCUkLz11c7rp+tbNTynGqc6mS1d5ATd/sGyV6W0KZZnXRKMTzZDRgQT3Ou9jhpAfUg==
+  dependencies:
+    "@babel/highlight" "^7.10.4"
+"@babel/generator@^7.11.5":
+  version "7.11.6"
+  resolved "https://registry.yarnpkg.com/@babel/generator/-/generator-7.11.6.tgz#b868900f81b163b4d464ea24545c61cbac4dc620"
+  integrity sha512-DWtQ1PV3r+cLbySoHrwn9RWEgKMBLLma4OBQloPRyDYvc5msJM9kvTLo1YnlJd1P/ZuKbdli3ijr5q3FvAF3uA==
+  dependencies:
+    "@babel/types" "^7.11.5"
+    jsesc "^2.5.1"
+    source-map "^0.5.0"
+"@babel/helper-function-name@^7.10.4":
+  version "7.10.4"
+  resolved "https://registry.yarnpkg.com/@babel/helper-function-name/-/helper-function-name-7.10.4.tgz#d2d3b20c59ad8c47112fa7d2a94bc09d5ef82f1a"
+  integrity sha512-YdaSyz1n8gY44EmN7x44zBn9zQ1Ry2Y+3GTA+3vH6Mizke1Vw0aWDM66FOYEPw8//qKkmqOckrGgTYa+6sceqQ==
+  dependencies:
+    "@babel/helper-get-function-arity" "^7.10.4"
+    "@babel/template" "^7.10.4"
+    "@babel/types" "^7.10.4"
+"@babel/helper-get-function-arity@^7.10.4":
+  version "7.10.4"
+  resolved "https://registry.yarnpkg.com/@babel/helper-get-function-arity/-/helper-get-function-arity-7.10.4.tgz#98c1cbea0e2332f33f9a4661b8ce1505b2c19ba2"
+  integrity sha512-EkN3YDB+SRDgiIUnNgcmiD361ti+AVbL3f3Henf6dqqUyr5dMsorno0lJWJuLhDhkI5sYEpgj6y9kB8AOU1I2A==
+  dependencies:
+"@babel/helper-split-export-declaration@^7.11.0":
+  version "7.11.0"
+  resolved "https://registry.yarnpkg.com/@babel/helper-split-export-declaration/-/helper-split-export-declaration-7.11.0.tgz#f8a491244acf6a676158ac42072911ba83ad099f"
+  integrity sha512-74Vejvp6mHkGE+m+k5vHY93FX2cAtrw1zXrZXRlG4l410Nm9PxfEiVTn1PjDPV5SnmieiueY4AFg2xqhNFuuZg==
+  dependencies:
+    "@babel/types" "^7.11.0"
+"@babel/helper-validator-identifier@^7.10.4":
+  version "7.10.4"
+  resolved "https://registry.yarnpkg.com/@babel/helper-validator-identifier/-/helper-validator-identifier-7.10.4.tgz#a78c7a7251e01f616512d31b10adcf52ada5e0d2"
+  integrity sha512-3U9y+43hz7ZM+rzG24Qe2mufW5KhvFg/NhnNph+i9mgCtdTCtMJuI1TMkrIUiK7Ix4PYlRF9I5dhqaLYA/ADXw==
+"@babel/highlight@^7.10.4":
+  version "7.10.4"
+  resolved "https://registry.yarnpkg.com/@babel/highlight/-/highlight-7.10.4.tgz#7d1bdfd65753538fabe6c38596cdb76d9ac60143"
+  integrity sha512-i6rgnR/YgPEQzZZnbTHHuZdlE8qyoBNalD6F+q4vAFlcMEcqmkoG+mPqJYJCo63qPf74+Y1UZsl3l6f7/RIkmA==
+  dependencies:
+    "@babel/helper-validator-identifier" "^7.10.4"
+    chalk "^2.0.0"
+    js-tokens "^4.0.0"
+"@babel/parser@^7.10.4", "@babel/parser@^7.11.5", "@babel/parser@^7.7.0":
+  version "7.11.5"
+  resolved "https://registry.yarnpkg.com/@babel/parser/-/parser-7.11.5.tgz#c7ff6303df71080ec7a4f5b8c003c58f1cf51037"
+  integrity sha512-X9rD8qqm695vgmeaQ4fvz/o3+Wk4ZzQvSHkDBgpYKxpD4qTAUm88ZKtHkVqIOsYFFbIQ6wQYhC6q7pjqVK0E0Q==
+"@babel/template@^7.10.4":
+  version "7.10.4"
+  resolved "https://registry.yarnpkg.com/@babel/template/-/template-7.10.4.tgz#3251996c4200ebc71d1a8fc405fba940f36ba278"
+  integrity sha512-ZCjD27cGJFUB6nmCB1Enki3r+L5kJveX9pq1SvAUKoICy6CZ9yD8xO086YXdYhvNjBdnekm4ZnaP5yC8Cs/1tA==
+  dependencies:
+    "@babel/code-frame" "^7.10.4"
+    "@babel/parser" "^7.10.4"
+"@babel/traverse@^7.7.0":
+  version "7.11.5"
+  resolved "https://registry.yarnpkg.com/@babel/traverse/-/traverse-7.11.5.tgz#be777b93b518eb6d76ee2e1ea1d143daa11e61c3"
+  integrity sha512-EjiPXt+r7LiCZXEfRpSJd+jUMnBd4/9OUv7Nx3+0u9+eimMwJmG0Q98lw4/289JCoxSE8OolDMNZaaF/JZ69WQ==
+  dependencies:
+    "@babel/generator" "^7.11.5"
+    "@babel/helper-function-name" "^7.10.4"
+    "@babel/helper-split-export-declaration" "^7.11.0"
+    "@babel/parser" "^7.11.5"
+    debug "^4.1.0"
+    globals "^11.1.0"
+    lodash "^4.17.19"
+"@babel/types@^7.10.4", "@babel/types@^7.11.0", "@babel/types@^7.11.5", "@babel/types@^7.7.0":
+  version "7.11.5"
+  resolved "https://registry.yarnpkg.com/@babel/types/-/types-7.11.5.tgz#d9de577d01252d77c6800cee039ee64faf75662d"
+  integrity sha512-bvM7Qz6eKnJVFIn+1LPtjlBFPVN5jNDc1XmN15vWe7Q3DPBufWWsLiIvUu7xW87uTG6QoggpIDnUgLQvPheU+Q==
+  dependencies:
+    lodash "^4.17.19"
+    to-fast-properties "^2.0.0"
+"@ember-data/rfc395-data@^0.0.4":
+  version "0.0.4"
+  resolved "https://registry.yarnpkg.com/@ember-data/rfc395-data/-/rfc395-data-0.0.4.tgz#ecb86efdf5d7733a76ff14ea651a1b0ed1f8a843"
GitHub sha: ec859e58
This commit appears in #12 which was merged by jjaffeux.
