DEV: apply ember-template-lint fixes (#126)
diff --git a/assets/javascripts/discourse/connectors/category-custom-settings/solved-settings.hbs b/assets/javascripts/discourse/connectors/category-custom-settings/solved-settings.hbs
index 51bcda7..4efa3e6 100644
--- a/assets/javascripts/discourse/connectors/category-custom-settings/solved-settings.hbs
+++ b/assets/javascripts/discourse/connectors/category-custom-settings/solved-settings.hbs
@@ -1,6 +1,6 @@
 {{#unless siteSettings.allow_solved_on_all_topics}}
-  <h3>{{i18n 'solved.title'}}</h3>
-  <section class='field'>
+  <h3>{{i18n "solved.title"}}</h3>
+  <section class="field">
     <div class="enable-accepted-answer">
       <label class="checkbox-label">
         {{input
@@ -8,7 +8,7 @@
           checked=(readonly category.enable_accepted_answers)
           change=(action "onChangeSetting" value="target.checked")
-        {{i18n 'solved.allow_accepted_answers'}}
+        {{i18n "solved.allow_accepted_answers"}}
       </label>
     </div>
   </section>
diff --git a/assets/javascripts/discourse/connectors/topic-after-cooked/solved-panel.hbs b/assets/javascripts/discourse/connectors/topic-after-cooked/solved-panel.hbs
index 168f0f6..7aa01d7 100644
--- a/assets/javascripts/discourse/connectors/topic-after-cooked/solved-panel.hbs
+++ b/assets/javascripts/discourse/connectors/topic-after-cooked/solved-panel.hbs
@@ -1,5 +1,5 @@
 {{#if topic.accepted_answer}}
-<p class="solved">
-{{{topic.acceptedAnswerHtml}}}
-</p>
+  <p class="solved">
+    {{html-safe topic.acceptedAnswerHtml}}
+  </p>
 {{/if}}
diff --git a/assets/javascripts/discourse/connectors/user-activity-bottom/solved-list.hbs b/assets/javascripts/discourse/connectors/user-activity-bottom/solved-list.hbs
index fc315b1..f4fc8f6 100644
--- a/assets/javascripts/discourse/connectors/user-activity-bottom/solved-list.hbs
+++ b/assets/javascripts/discourse/connectors/user-activity-bottom/solved-list.hbs
@@ -1,3 +1,3 @@
-{{#link-to 'userActivity.solved'}}
-  {{d-icon 'check-square'}} {{i18n 'solved.title'}}
+{{#link-to "userActivity.solved"}}
+  {{d-icon "check-square"}} {{i18n "solved.title"}}
 {{/link-to}}
diff --git a/assets/javascripts/discourse/connectors/user-summary-stat/solved-count.hbs b/assets/javascripts/discourse/connectors/user-summary-stat/solved-count.hbs
index ee330d5..cad2b11 100644
--- a/assets/javascripts/discourse/connectors/user-summary-stat/solved-count.hbs
+++ b/assets/javascripts/discourse/connectors/user-summary-stat/solved-count.hbs
@@ -1,3 +1,7 @@
-  {{user-stat value=model.solved_count label="solved.solution_summary" icon="check-square"}}
+  {{user-stat
+    value=model.solved_count
+    label="solved.solution_summary"
+    icon="check-square"
 {{/link-to}}
GitHub sha: a6f911b9
This commit appears in #126 which was approved by CvX. It was merged by jjaffeux.
