DEV: bumping for customHref nav item API (#8029)
diff --git a/app/assets/javascripts/discourse/lib/plugin-api.js.es6 b/app/assets/javascripts/discourse/lib/plugin-api.js.es6
index 4ecac87..950fdcd 100644
--- a/app/assets/javascripts/discourse/lib/plugin-api.js.es6
+++ b/app/assets/javascripts/discourse/lib/plugin-api.js.es6
@@ -45,7 +45,7 @@ import { addCategorySortCriteria } from "discourse/components/edit-category-sett
 import { queryRegistry } from "discourse/widgets/widget";
 // If you add any methods to the API ensure you bump up this number
-const PLUGIN_API_VERSION = "0.8.31";
+const PLUGIN_API_VERSION = "0.8.32";
 class PluginApi {
   constructor(version, container) {
GitHub sha: 78eb05e4
