DEV: Catch Mocha::ExpectationError in request specs (#14897)
Same issue as 28b00dc6fc4f9903c7bd0d4a84aabee1b4391e74, the Mocha::ExpectationError inherits from Exception instead of StandardError so RspecErrorTracker does not show the actual failed expectation in request specs, the status of the response is just 500 with no further detail.
diff --git a/spec/rails_helper.rb b/spec/rails_helper.rb
index 18c9956..18e3210 100644
--- a/spec/rails_helper.rb
+++ b/spec/rails_helper.rb
@@ -46,9 +46,9 @@ class RspecErrorTracker
       @app.call(env)
     # This is a little repetitive, but since WebMock::NetConnectNotAllowedError
-    # inherits from Exception instead of StandardError it does not get captured
-    # by the rescue => e shorthand :(
-    rescue WebMock::NetConnectNotAllowedError, StandardError => e
+    # and also Mocha::ExpectationError inherit from Exception instead of StandardError
+    # they do not get captured by the rescue => e shorthand :(
+    rescue WebMock::NetConnectNotAllowedError, Mocha::ExpectationError, StandardError => e
       RspecErrorTracker.last_exception = e
       raise e
GitHub sha: e0be6ce1ee703d9ddd7cdf16c1bae52b553f085d
This commit appears in #14897 which was approved by tgxworld. It was merged by martin.
