DEV: Check English locale for errors in CI
Moves the most important checks into a linter. It gets executed by Lefthook as well as the docker rake task and Github actions. Doing those checks in rspec takes too long and it produces errors when the discourse:test Docker image contains old, invalid locale files.
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index b5a33d7..7e7ce7f 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -6,7 +6,7 @@ on:
       - master
   pull_request:
     branches-ignore:
-      - 'tests-passed'
+      - "tests-passed"
 jobs:
   build:
@@ -28,12 +28,12 @@ jobs:
       fail-fast: false
       matrix:
-        build_types: [ 'BACKEND', 'FRONTEND', 'LINT' ]
-        target: [ 'PLUGINS', 'CORE' ]
-        os: [ ubuntu-latest ]
-        ruby: [ '2.6' ]
-        postgres: [ '10' ]
-        redis: [ '4.x' ]
+        build_types: ["BACKEND", "FRONTEND", "LINT"]
+        target: ["PLUGINS", "CORE"]
+        os: [ubuntu-latest]
+        ruby: ["2.6"]
+        postgres: ["10"]
+        redis: ["4.x"]
     services:
       postgres:
@@ -77,7 +77,7 @@ jobs:
         uses: actions/setup-ruby@v1
         with:
           ruby-version: ${{ matrix.ruby }}
-          architecture: 'x64'
+          architecture: "x64"
       - name: Setup bundler
         run: |
@@ -145,6 +145,14 @@ jobs:
           yarn prettier -v
           yarn prettier --list-different "app/assets/stylesheets/**/*.scss" "app/assets/javascripts/**/*.js" "app/assets/javascripts/**/*.es6" "test/javascripts/**/*.es6" "plugins/**/*.scss" "plugins/**/*.es6"
+      - name: Core English locale
+        if: env.BUILD_TYPE == 'LINT' && env.TARGET == 'CORE'
+        run: bundle exec ruby script/i18n_lint.rb "config/**/locales/{client,server}.en.yml"
+      - name: Plugin English locale
+        if: env.BUILD_TYPE == 'LINT' && env.TARGET == 'PLUGINS'
+        run: bundle exec ruby script/i18n_lint.rb "plugins/**/locales/{client,server}.en.yml"
       - name: Core RSpec
         if: env.BUILD_TYPE == 'BACKEND' && env.TARGET == 'CORE'
         run: |
@@ -167,5 +175,5 @@ jobs:
       - name: Plugin QUnit # Tests core plugins in TARGET=CORE, and all plugins in TARGET=PLUGINS
         if: env.BUILD_TYPE == 'FRONTEND'
-        run: bundle exec rake plugin:qunit
+        run: bundle exec rake plugin:qunit['*','1200000']
         timeout-minutes: 30
diff --git a/lefthook.yml b/lefthook.yml
index f3645c3..65fe913 100644
--- a/lefthook.yml
+++ b/lefthook.yml
@@ -23,6 +23,9 @@ pre-commit:
       # database.yml is an erb file not a yaml file
       exclude: "database.yml"
       run: bundle exec yaml-lint {staged_files}
+    i18n-lint:
+      glob: "**/{client,server}.en.yml"
+      run: bundle exec ruby script/i18n_lint.rb {staged_files}
 commands: &commands
   bundle-install:
@@ -58,8 +61,11 @@ lints:
     eslint-test:
       run: yarn eslint --ext .es6 test/javascripts
     eslint-plugins-assets:
-      run: yarn eslint --ext .es6 plugins/**/assets/javascripts
+      run: yarn eslint --global I18n --ext .es6 plugins/**/assets/javascripts
     eslint-plugins-test:
-      run: yarn eslint --ext .es6 plugins/**/test/javascripts
+      run: yarn eslint --global I18n --ext .es6 plugins/**/test/javascripts
     eslint-assets-tests:
       run: yarn eslint app/assets/javascripts test/javascripts
+    i18n-lint:
+      run: bundle exec ruby script/i18n_lint.rb {all_files}
diff --git a/lib/tasks/docker.rake b/lib/tasks/docker.rake
index 6733ae3..b0d2e6e 100644
--- a/lib/tasks/docker.rake
+++ b/lib/tasks/docker.rake
@@ -66,6 +66,7 @@ task 'docker:test' do
       if ENV["SINGLE_PLUGIN"]
         @good &&= run_or_fail("bundle exec rubocop --parallel plugins/#{ENV["SINGLE_PLUGIN"]}")
+        @good &&= run_or_fail("bundle exec ruby script/i18n_lint.rb plugins/#{ENV["SINGLE_PLUGIN"]}/config/locales/{client,server}.en.yml")
         @good &&= run_or_fail("yarn eslint --global I18n --ext .es6 plugins/#{ENV['SINGLE_PLUGIN']}")
         puts "Listing prettier offenses in #{ENV['SINGLE_PLUGIN']}:"
@@ -78,6 +79,9 @@ task 'docker:test' do
         # TODO: remove --global I18n once plugins can be updated
         @good &&= run_or_fail("yarn eslint --global I18n --ext .es6 plugins") unless ENV["SKIP_PLUGINS"]
+        @good &&= run_or_fail('bundle exec ruby script/i18n_lint.rb "config/locales/{client,server}.en.yml"') unless ENV["SKIP_CORE"]
+        @good &&= run_or_fail('bundle exec ruby script/i18n_lint.rb "plugins/**/locales/{client,server}.en.yml"') unless ENV["SKIP_PLUGINS"]
           puts "Listing prettier offenses in core:"
           @good &&= run_or_fail('yarn prettier --list-different "app/assets/stylesheets/**/*.scss" "app/assets/javascripts/**/*.es6" "test/javascripts/**/*.es6"')
diff --git a/script/i18n_lint.rb b/script/i18n_lint.rb
new file mode 100644
index 0000000..298efbc
--- /dev/null
+++ b/script/i18n_lint.rb
@@ -0,0 +1,129 @@
+require 'colored2'
+require 'psych'
+class I18nLinter
+  def initialize(filenames_or_patterns)
+    @filenames = filenames_or_patterns.map { |fp| Dir[fp] }.flatten
+    @errors = {}
+  end
+  def run
+    has_errors = false
+    @filenames.each do |filename|
+      validator = LocaleFileValidator.new(filename)
+      if validator.has_errors?
+        validator.print_errors
+        has_errors = true
+      end
+    end
+    exit 1 if has_errors
+  end
+end
+class LocaleFileValidator
+  ERROR_MESSAGES = {
+    invalid_relative_links: "The following keys have relative links, but do not start with %{base_url} or %{base_path}:",
+    invalid_relative_image_sources: "The following keys have relative image sources, but do not start with %{base_url} or %{base_path}:",
+    invalid_interpolation_key_format: "The following keys use {{key}} instead of %{key} for interpolation keys:",
+    wrong_pluralization_keys: "Pluralized strings must have only the sub-keys 'one' and 'other'.\nThe following keys have missing or additional keys:",
+    invald_one_keys: "The following keys contain the number 1 instead of the interpolation key %{count}:"
+  PLURALIZATION_KEYS = ['zero', 'one', 'two', 'few', 'many', 'other']
+  ENGLISH_KEYS = ['one', 'other']
+  def initialize(filename)
+    @filename = filename
+    @errors = {}
+  end
+  def has_errors?
+    yaml = Psych.safe_load(File.read(@filename), aliases: true)
+    yaml = yaml[yaml.keys.first]
+    validate_pluralizations(yaml)
+    validate_content(yaml)
+    @errors.any? { |_, value| value.any? }
+  end
+  def print_errors
+    puts "", "Errors in #{@filename}".red
+    @errors.each do |type, keys|
+      next if keys.empty?
+      ERROR_MESSAGES[type].split("\n").each { |msg| puts "  #{msg}" }
+      keys.each { |key| puts "    * #{key}" }
+    end
+  end
+  private
+  def each_translation(hash, parent_key = '', &block)
+    hash.each do |key, value|
+      current_key = parent_key.empty? ? key : "#{parent_key}.#{key}"
+      if Hash === value
+        each_translation(value, current_key, &block)
+      else
+        yield(current_key, value.to_s)
+      end
+    end
+  end
+  def validate_content(yaml)
+    @errors[:invalid_relative_links] = []
+    @errors[:invalid_relative_image_sources] = []
+    @errors[:invalid_interpolation_key_format] = []
+    each_translation(yaml) do |key, value|
+      if value.match?(/href\s*=\s*["']\/[^\/]|\]\(\/[^\/]/i)
+        @errors[:invalid_relative_links] << key
+      end
+      if value.match?(/src\s*=\s*["']\/[^\/]/i)
+        @errors[:invalid_relative_image_sources] << key
+      end
+      if value.match?(/{{.+?}}/) && !key.end_with?("_MF")
+        @errors[:invalid_interpolation_key_format] << key
+      end
+    end
+  end
+  def each_pluralization(hash, parent_key = '', &block)
+      if Hash === value
+        each_pluralization(value, current_key, &block)
+      elsif PLURALIZATION_KEYS.include? key
+        yield(parent_key, hash)
+      end
+    end
+  end
+  def validate_pluralizations(yaml)
+    @errors[:wrong_pluralization_keys] = []
GitHub sha: f683c5d0
This commit appears in #9974 which was approved by eviltrout. It was merged by gschlager.
