DEV: check for google-chrome-stable first
on my distro google-chrome-stable is the only binary created when installing chrome, this ensures we check for it first
diff --git a/lib/autospec/qunit_runner.rb b/lib/autospec/qunit_runner.rb
index 91e3d39..7df2f5a 100644
--- a/lib/autospec/qunit_runner.rb
+++ b/lib/autospec/qunit_runner.rb
@@ -114,9 +114,13 @@ module Autospec
     private
     def ensure_chrome_is_installed
-      raise ChromeNotInstalled.new unless system("command -v google-chrome >/dev/null;")
-      if Gem::Version.new(`$(command -v google-chrome) --version`.match(/[\d\.]+/)[0]) < Gem::Version.new("59")
+      binary = "google-chrome-stable" if system("command -v google-chrome-stable >/dev/null;")
+      binary ||= "google-chrome" if system("command -v google-chrome >/dev/null;")
+      raise ChromeNotInstalled.new if !binary
+      if Gem::Version.new(`#{binary} --version`.match(/[\d\.]+/)[0]) < Gem::Version.new("59")
         raise "Chrome 59 or higher is required"
GitHub sha: 21c47543
