DEV: Clean up .gitignore (#12981)
(inspired by martin-brennan’s recent adventure with tags exclusion)
tl;dr: some of it is obsolete, some is dev-env specific and should live in your ~/.gitignore.
To enable global gitignore (~/.gitignore) run:
git config --global core.excludesFile '~/.gitignore'
Then create that file and add your VIM/VSCode/Sublime/Emacs/Eclipse/RubyMine/JetBrains/macOS/Arch/Windows 95-specific stuff.
Reasons for removal:
  • bin - never really ignored, all the files are checked in
  • .DS_Store, ._.DS_Store - OS specific
  • .sass-cache/*, /.bundle, /bundle/*, /cache, /logfile, !/plugins/discourse-nginx-performance-report, MiniProfiler/Ruby/rack-mini-profiler-2.0.1a.gem, config/fog_credentials.yml, /public/stylesheet-cache/*, script/download_db, script/refresh_db, config/version.rb - no longer used?
  • /log/*.log - covered by /log
  • bootsnap-load-path-cache, bootsnap-compile-cache - bootsnap now keeps its trash temporary files in /tmp
  • /.project, /.buildpath, /.byebug_history, /.idea, discourse.sublime-workspace, *~, *.swp, *.swo, *.swm, config/multisite1.yml, .rvmrc, .ruby-version, .ruby-gemset, .rbenv, bundler_stubs/*, *.db, *.iml, *.swn, /package-lock.json, .vscode, .envrc, tags - dev-env specific, see the note at the top of the commit
diff --git a/.gitignore b/.gitignore
index 5de911e..8aea19b 100644
--- a/.gitignore
+++ b/.gitignore
@@ -1,33 +1,26 @@
-# See http://help.github.com/ignore-files/ for more about ignoring files.
-# If you find yourself ignoring temporary files generated by your text editor
-# or operating system, you probably want to add a global ignore instead:
-#   git config --global core.excludesfile ~/.gitignore_global
-.DS_Store
-._.DS_Store
-dump.rdb
-bin/*
-data/
-.sass-cache/*
-public/csv/*
-public/plugins/*
-public/tombstone/*
+/copyright
+/coverage
+/data
+/log
+/tmp
-# Ignore bundler config
-/.bundle
-/cache
-/coverage/*
+/.env
+/.procfile
+/dump.rdb
-/public/assets/*
-/public/tombstone/*
-/bundle/*
+/config/discourse.conf
+/config/discourse.pill
+/config/multisite.yml
+# `discourse_dev` gem
+/config/dev.yml
-config/discourse.pill
-config/discourse.conf
+/public/assets
+/public/backups
+/public/csv
+/public/fonts
+/public/plugins
+/public/tombstone
+/public/uploads
 # Ignore the default SQLite database and db dumps
 *.sql
@@ -38,120 +31,29 @@ config/discourse.conf
 /db/schema.rb
 /db/schema_cache.yml
-# Ignore all logfiles and tempfiles.
-/log/*.log
-/tmp
-/logfile
-log/
-bootsnap-load-path-cache
-bootsnap-compile-cache/
-# Ignore plugins except for the bundled ones.
+# Plugins except for the bundled ones
 /plugins/*
-!/plugins/lazy-yt/
-!/plugins/poll/
 !/plugins/discourse-details/
-!/plugins/discourse-nginx-performance-report
+!/plugins/discourse-local-dates
 !/plugins/discourse-narrative-bot
 !/plugins/discourse-presence
+!/plugins/lazy-yt/
+!/plugins/poll/
 !/plugins/styleguide
-!/plugins/discourse-local-dates
 /plugins/*/auto_generated/
 /spec/fixtures/plugins/my_plugin/auto_generated
-# Ignore Eclipse .project file
-/.project
-# Ignore Eclipse .buildpath file
-/.buildpath
-# Ignore byebug history
-/.byebug_history
-# Ignore RubyMine settings
-/.idea
-# Ignore gem that is copied in
-MiniProfiler/Ruby/rack-mini-profiler-2.0.1a.gem
-discourse.sublime-workspace
-# Vim temp files
-*.swp
-*.swo
-*.swm
-# don't check in multisite config
-config/multisite.yml
-# don't check in my renamed multisite config as well :)
-config/multisite1.yml
-config/fog_credentials.yml
-/public/fonts
-/public/uploads
-/public/backups
-/public/stylesheet-cache/*
-# Scripts used for downloading/refreshing db
-script/download_db
-script/refresh_db
-# .procfile
-.procfile
-# .env, local environment variables for use with foreman
-.env
-# exclude our git version file for now
-config/version.rb
-# ignore the Ruby Version manager (rvm)
-.rvmrc
-.ruby-version
-.ruby-gemset
-.rbenv
-bundler_stubs/*
-vendor/bundle/*
-*.db
-# ignore jetbrains ide file
-*.iml
-# vim swap
-*.swn
-# ignore nodejs files
-node_modules
-/package-lock.json
+/vendor/bundle/*
 /vendor/data/GeoLite2-City.mmdb
-# Vagrant
-.vagrant
+# Front-end
+dist
+node_modules
+yarn-error.log
-# ignore auto-generated plugin js assets
+# Auto-generated plugin JS assets
 /app/assets/javascripts/plugins/*
-# ignore generated api documentation files
+# Generated API documentation files
 openapi/*
-# ignore VSCode config files
-.vscode
-# ignore direnv
-.envrc
-# ember-cli generated
-dist
-# Copyright Deposits
-copyright
-yarn-error.log
-tags
-# file used with `discourse_dev` gem in development environment.
-config/dev.yml
diff --git a/bin/rubocop b/bin/rubocop
new file mode 100755
index 0000000..d0c4882
--- /dev/null
+++ b/bin/rubocop
@@ -0,0 +1,29 @@
+#!/usr/bin/env ruby
+# This file was generated by Bundler.
+# The application 'rubocop' is installed as part of a gem, and
+# this file is here to facilitate running it.
+require "pathname"
+ENV["BUNDLE_GEMFILE"] ||= File.expand_path("../../Gemfile",
+  Pathname.new(__FILE__).realpath)
+bundle_binstub = File.expand_path("../bundle", __FILE__)
+if File.file?(bundle_binstub)
+  if File.read(bundle_binstub, 300) =~ /This file was generated by Bundler/
+    load(bundle_binstub)
+  else
+    abort("Your `bin/bundle` was not generated by Bundler, so this binstub cannot run.
+Replace `bin/bundle` by running `bundle binstubs bundler --force`, then run this command again.")
+  end
+end
+require "rubygems"
+require "bundler/setup"
+load Gem.bin_path("rubocop", "rubocop")
GitHub sha: 53c06442
This commit appears in #12981 which was approved by eviltrout and pmusaraj. It was merged by CvX.
