DEV: Clean up the spec
diff --git a/plugins/discourse-narrative-bot/spec/jobs/onceoff/remap_old_bot_images_spec.rb b/plugins/discourse-narrative-bot/spec/jobs/onceoff/remap_old_bot_images_spec.rb
index 6543cbd..76cf623 100644
--- a/plugins/discourse-narrative-bot/spec/jobs/onceoff/remap_old_bot_images_spec.rb
+++ b/plugins/discourse-narrative-bot/spec/jobs/onceoff/remap_old_bot_images_spec.rb
@@ -2,19 +2,15 @@
 require 'rails_helper'
-RSpec.describe Jobs::DiscourseNarrativeBot::RemapOldBotImages do
+describe Jobs::DiscourseNarrativeBot::RemapOldBotImages do
   context "when bot's post contains an old link" do
-    let(:post) do
+    let!(:post) do
       Fabricate(:post,
         user: ::DiscourseNarrativeBot::Base.new.discobot_user,
         raw: 'If you’d like to learn more, select <img src="/images/font-awesome-gear.png" width="16" height="16"> <img src="/images/font-awesome-ellipsis.png" width="16" height="16"> below  and <img src="/images/font-awesome-bookmark.png" width="16" height="16"> **bookmark this private message**.  If you do, there may be a :gift: in your future!'
-    before do
-      post
-    end
     it 'should remap the links correctly' do
       expected_raw = 'If you’d like to learn more, select <img src="/plugins/discourse-narrative-bot/images/font-awesome-gear.png" width="16" height="16"> <img src="/plugins/discourse-narrative-bot/images/font-awesome-ellipsis.png" width="16" height="16"> below  and <img src="/plugins/discourse-narrative-bot/images/font-awesome-bookmark.png" width="16" height="16"> **bookmark this private message**.  If you do, there may be a :gift: in your future!'
@@ -23,22 +19,22 @@ RSpec.describe Jobs::DiscourseNarrativeBot::RemapOldBotImages do
         expect(post.reload.raw).to eq(expected_raw)
+  end
-    context 'subfolder' do
-      let(:post) do
-        Fabricate(:post,
-          user: ::DiscourseNarrativeBot::Base.new.discobot_user,
-          raw: 'If you’d like to learn more, select <img src="/community/images/font-awesome-ellipsis.png" width="16" height="16"> below  and <img src="/community/images/font-awesome-bookmark.png" width="16" height="16"> **bookmark this private message**.  If you do, there may be a :gift: in your future!'
-      end
+  context 'subfolder' do
+    let!(:post) do
+      Fabricate(:post,
+        user: ::DiscourseNarrativeBot::Base.new.discobot_user,
+        raw: 'If you’d like to learn more, select <img src="/community/images/font-awesome-ellipsis.png" width="16" height="16"> below  and <img src="/community/images/font-awesome-bookmark.png" width="16" height="16"> **bookmark this private message**.  If you do, there may be a :gift: in your future!'
+    end
-      it 'should remap the links correctly' do
-        described_class.new.execute_onceoff({})
+    it 'should remap the links correctly' do
+      described_class.new.execute_onceoff({})
-        expect(post.reload.raw).to eq(
-          'If you’d like to learn more, select <img src="/community/plugins/discourse-narrative-bot/images/font-awesome-ellipsis.png" width="16" height="16"> below  and <img src="/community/plugins/discourse-narrative-bot/images/font-awesome-bookmark.png" width="16" height="16"> **bookmark this private message**.  If you do, there may be a :gift: in your future!'
-      end
+      expect(post.reload.raw).to eq(
+        'If you’d like to learn more, select <img src="/community/plugins/discourse-narrative-bot/images/font-awesome-ellipsis.png" width="16" height="16"> below  and <img src="/community/plugins/discourse-narrative-bot/images/font-awesome-bookmark.png" width="16" height="16"> **bookmark this private message**.  If you do, there may be a :gift: in your future!'
GitHub sha: bd2b2bcf9c997fc83fc6825c49ec6488babeca91
This commit appears in #13317 which was approved by tgxworld. It was merged by tgxworld.
