DEV: Cleanup PostActionType and ReviewableScore changes in tests
Followup to 2df388ffd7279ec7738691bf133ef2a63834610e
diff --git a/spec/components/plugin/instance_spec.rb b/spec/components/plugin/instance_spec.rb
index 34e3905..1f31790 100644
--- a/spec/components/plugin/instance_spec.rb
+++ b/spec/components/plugin/instance_spec.rb
@@ -555,6 +555,11 @@ describe Plugin::Instance do
   describe '#replace_flags' do
+    after do
+      PostActionType.replace_flag_settings(nil)
+      ReviewableScore.reload_types
+    end
     let(:original_flags) { PostActionType.flag_settings }
     it 'adds a new flag' do
GitHub sha: da0fc0a9
