DEV: convert scheduled job EnsurePostUploadsExistence into a rake task
diff --git a/app/jobs/scheduled/ensure_post_uploads_existence.rb b/app/jobs/scheduled/ensure_post_uploads_existence.rb
deleted file mode 100644
index ea1103d..0000000
--- a/app/jobs/scheduled/ensure_post_uploads_existence.rb
+++ /dev/null
@@ -1,47 +0,0 @@
-# frozen_string_literal: true
-module Jobs
-  class EnsurePostUploadsExistence < Jobs::Scheduled
-    every 1.hour
-    MISSING_UPLOADS ||= "missing_uploads"
-    def execute(args)
-      return unless SiteSetting.enable_missing_post_uploads_check?
-      PostCustomField
-        .where(name: MISSING_UPLOADS)
-        .where("created_at < ?", 1.month.ago)
-        .destroy_all
-      Post
-        .joins("LEFT JOIN post_custom_fields cf ON posts.id = cf.post_id AND cf.name = '#{MISSING_UPLOADS}'")
-        .where("(posts.cooked LIKE '%<a %' OR posts.cooked LIKE '%<img %') AND cf.id IS NULL")
-        .find_in_batches(batch_size: 100) do |posts|
-        Post.preload_custom_fields(posts, [MISSING_UPLOADS])
-        posts.each do |post|
-          fragments ||= Nokogiri::HTML::fragment(post.cooked)
-          missing = []
-          fragments.css("a/@href", "img/@src").each do |media|
-            src = media.value
-            next if src.blank? || (src =~ /\/uploads\//).blank?
-            src = "#{SiteSetting.force_https ? "https" : "http"}:#{src}" if src.start_with?("//")
-            next unless Discourse.store.has_been_uploaded?(src) || src =~ /\A\/[^\/]/i
-            missing << src unless Upload.get_from_url(src) || OptimizedImage.get_from_url(src)
-          end
-          if missing.present?
-            missing.each { |src| PostCustomField.create!(post_id: post.id, name: MISSING_UPLOADS, value: src) }
-          else
-            PostCustomField.create!(post_id: post.id, name: MISSING_UPLOADS, value: nil)
-          end
-        end
-      end
-    end
-  end
-end
diff --git a/app/models/concerns/has_url.rb b/app/models/concerns/has_url.rb
new file mode 100644
index 0000000..eca6cf9
--- /dev/null
+++ b/app/models/concerns/has_url.rb
@@ -0,0 +1,24 @@
+module HasUrl
+  extend ActiveSupport::Concern
+  class_methods do
+    def extract_url(url)
+      url.match(self::URL_REGEX)
+    end
+    def get_from_url(url)
+      return if url.blank?
+      uri = begin
+        URI(URI.unescape(url))
+      rescue URI::Error
+      end
+      return if uri&.path.blank?
+      data = extract_url(uri.path)
+      return if data.blank?
+      self.find_by("url LIKE ?", "%#{data[1]}")
+    end
+  end
+end
diff --git a/app/models/optimized_image.rb b/app/models/optimized_image.rb
index ab0f9db..9dc037e 100644
--- a/app/models/optimized_image.rb
+++ b/app/models/optimized_image.rb
@@ -4,10 +4,12 @@ require_dependency "db_helper"
 require_dependency "file_store/local_store"
 class OptimizedImage < ActiveRecord::Base
+  include HasUrl
   belongs_to :upload
   # BUMP UP if optimized image algorithm changes
   VERSION = 2
+  URL_REGEX ||= /(\/optimized\/\dX[\/\.\w]*\/([a-zA-Z0-9]+)[\.\w]*)/
   def self.lock(upload_id, width, height)
     @hostname ||= `hostname`.strip rescue "unknown"
@@ -350,25 +352,6 @@ class OptimizedImage < ActiveRecord::Base
       false
-  def self.extract_optimized_url(url)
-    url.match(/(\/optimized\/\dX[\/\.\w]*\/([a-zA-Z0-9]+)[\.\w]*)/)
-  end
-  def self.get_from_url(url)
-    return if url.blank?
-    uri = begin
-      URI(URI.unescape(url))
-    rescue URI::Error
-    end
-    return if uri&.path.blank?
-    data = extract_optimized_url(uri.path)
-    return if data.blank?
-    OptimizedImage.find_by("url LIKE ?", "%#{data[1]}")
-  end
 # == Schema Information
diff --git a/app/models/upload.rb b/app/models/upload.rb
index 4149582..8b3088c 100644
--- a/app/models/upload.rb
+++ b/app/models/upload.rb
@@ -8,9 +8,11 @@ require_dependency "base62"
 class Upload < ActiveRecord::Base
   include ActionView::Helpers::NumberHelper
+  include HasUrl
   SHA1_LENGTH = 40
   SEEDED_ID_THRESHOLD = 0
+  URL_REGEX ||= /(\/original\/\dX[\/\.\w]*\/([a-zA-Z0-9]+)[\.\w]*)/
   belongs_to :user
@@ -192,27 +194,6 @@ class Upload < ActiveRecord::Base
     Digest::SHA1.file(path).hexdigest
-  def self.extract_upload_url(url)
-    url.match(/(\/original\/\dX[\/\.\w]*\/([a-zA-Z0-9]+)[\.\w]*)/)
-  end
-    uri = begin
-    rescue URI::Error
-    end
-    data = extract_upload_url(uri.path)
-    sha1 = data[2]
-    upload = nil
-    upload = Upload.find_by(sha1: sha1) if sha1&.length == SHA1_LENGTH
-    upload || Upload.find_by("url LIKE ?", "%#{data[1]}")
-  end
   def human_filesize
     number_to_human_size(self.filesize)
diff --git a/config/site_settings.yml b/config/site_settings.yml
index 55a1ff1..7e31adf 100644
--- a/config/site_settings.yml
+++ b/config/site_settings.yml
@@ -1481,9 +1481,6 @@ developer:
   enable_safe_mode:
     default: true
     client: true
-  enable_missing_post_uploads_check:
-    default: false
-    hidden: true
 embedding:
   feed_polling_enabled:
diff --git a/lib/tasks/posts.rake b/lib/tasks/posts.rake
index 0c78987..09f2242 100644
--- a/lib/tasks/posts.rake
+++ b/lib/tasks/posts.rake
@@ -387,3 +387,28 @@ task 'posts:reorder_posts', [:topic_id] => [:environment] do |_, args|
   puts "", "Done.", ""
+desc 'Finds missing post upload records from cooked HTML content'
+task 'posts:missing_uploads' => :environment do
+  name = "missing_uploads"
+  PostCustomField.where(name: name).destroy_all
+  posts = Post.where("posts.cooked LIKE '%<a %' OR posts.cooked LIKE '%<img %'").select(:id, :cooked)
+  missing = []
+  posts.find_each do |post|
+    Nokogiri::HTML::fragment(post.cooked).css("a/@href", "img/@src").each do |media|
+      src = media.value
+      next if src.blank? || (src =~ /\/uploads\//).blank?
+      src = "#{SiteSetting.force_https ? "https" : "http"}:#{src}" if src.start_with?("//")
+      next unless Discourse.store.has_been_uploaded?(src) || src =~ /\A\/[^\/]/i
+      missing << src unless Upload.get_from_url(src) || OptimizedImage.get_from_url(src)
+    end
+    missing.each { |src| PostCustomField.create!(post_id: post.id, name: name, value: src) }
+    putc "."
+  end
+  puts "", "#{missing.count} post uploads are missing.", ""
+end
diff --git a/spec/jobs/ensure_post_uploads_existence_spec.rb b/spec/jobs/ensure_post_uploads_existence_spec.rb
index 99d187a..0000000
--- a/spec/jobs/ensure_post_uploads_existence_spec.rb
+++ /dev/null
@@ -1,47 +0,0 @@
-require 'rails_helper'
-describe Jobs::EnsurePostUploadsExistence do
-  context '.execute' do
-    let(:upload) { Fabricate(:upload) }
-    let(:optimized) { Fabricate(:optimized_image, url: '/uploads/default/optimized/1X/d1c2d40ab994e8410c_100x200.png') }
-    context "when enabled" do
-      before do
-        SiteSetting.enable_missing_post_uploads_check = true
-      end
-      it 'should create post custom field for missing upload' do
-        Fabricate(:post, cooked: "A sample post <img src='#{upload.url}'>")
-        upload.destroy!
-        described_class.new.execute({})
-        field = PostCustomField.find_by(name: Jobs::EnsurePostUploadsExistence::MISSING_UPLOADS)
-        expect(field).to be_present
-        expect(field.value).to eq(upload.url)
-      end
-      it 'should create post custom field with nil value' do
-        Fabricate(:post, cooked: "A sample post <a href='#{upload.url}'> <img src='#{optimized.url}'>")
-        expect(field.value).to eq(nil)
-      end
-    end
-    context "when disabled" do
-      before do
-        SiteSetting.enable_missing_post_uploads_check = false
-      end
-      it "does not execute" do
GitHub sha: 914ada1c
@vinothkannans Ah this shouldn’t have been removed. Searching by sha1 is much faster than trying to match on URL because of the index we have on sha1.
Fix regression due to 914ada1c749425c4eb53b2d8338afa6b4ab3f3d4.
