DEV: correct flaky poll specs
approved
heisentest
#1
They were relying on a pristine message bus, however current implementation still uses redis, stuff can get held up and we can end up publishing distributed cache messages in the middle invalidating the tests
diff --git a/plugins/poll/spec/controllers/polls_controller_spec.rb b/plugins/poll/spec/controllers/polls_controller_spec.rb
index 016bde3..78f86e3 100644
--- a/plugins/poll/spec/controllers/polls_controller_spec.rb
+++ b/plugins/poll/spec/controllers/polls_controller_spec.rb
@@ -15,7 +15,9 @@ describe ::DiscoursePoll::PollsController do
   describe "#vote" do
     it "works" do
-      message = MessageBus.track_publish do
+      channel = "/polls/#{poll.topic_id}"
+      message = MessageBus.track_publish(channel) do
         put :vote, params: {
           post_id: poll.id, poll_name: "poll", options: ["5c24fc1df56d764b550ceae1b9319125"]
         }, format: :json
@@ -28,7 +30,7 @@ describe ::DiscoursePoll::PollsController do
       expect(json["poll"]["voters"]).to eq(1)
       expect(json["vote"]).to eq(["5c24fc1df56d764b550ceae1b9319125"])
-      expect(message.channel).to eq("/polls/#{poll.topic_id}")
+      expect(message.channel).to eq(channel)
       expect(message.user_ids).to eq(nil)
       expect(message.group_ids).to eq(nil)
@@ -41,7 +43,9 @@ describe ::DiscoursePoll::PollsController do
       poll = Fabricate(:post, topic: topic, user: user, raw: "[poll]\n- A\n- B\n[/poll]")
         }, format: :json
@@ -54,7 +58,7 @@ describe ::DiscoursePoll::PollsController do
       expect(message.user_ids).to contain_exactly(user.id, user2.id)
@@ -66,7 +70,9 @@ describe ::DiscoursePoll::PollsController do
       topic = Fabricate(:topic, category: category)
         }, format: :json
@@ -79,7 +85,7 @@ describe ::DiscoursePoll::PollsController do
       expect(message.group_ids).to contain_exactly(group.id)
@@ -202,7 +208,9 @@ describe ::DiscoursePoll::PollsController do
   describe "#toggle_status" do
     it "works for OP" do
         put :toggle_status, params: {
           post_id: poll.id, poll_name: "poll", status: "closed"
         }, format: :json
@@ -212,13 +220,15 @@ describe ::DiscoursePoll::PollsController do
       json = ::JSON.parse(response.body)
       expect(json["poll"]["status"]).to eq("closed")
     it "works for staff" do
       log_in(:moderator)
         }, format: :json
@@ -228,7 +238,7 @@ describe ::DiscoursePoll::PollsController do
     it "ensures post is not trashed" do
@@ -305,7 +315,7 @@ describe ::DiscoursePoll::PollsController do
       expect(json["voters"][first].size).to eq(1)
-      user2 = log_in
+      _user2 = log_in
       get :voters, params: {
         poll_name: "poll", post_id: public_poll_on_vote.id
GitHub sha: aeb7143a
Approved #2
