DEV: Correct spec for theme export change
diff --git a/spec/components/theme_store/tgz_exporter_spec.rb b/spec/components/theme_store/tgz_exporter_spec.rb
index fb9f32d..94df8a8 100644
--- a/spec/components/theme_store/tgz_exporter_spec.rb
+++ b/spec/components/theme_store/tgz_exporter_spec.rb
@@ -50,15 +50,15 @@ describe ThemeStore::TgzExporter do
     filename = exporter.package_filename
     FileUtils.cp(filename, dir)
     exporter.cleanup!
-    "#{dir}/discourse-header-icons-theme.tar.gz"
+    "#{dir}/discourse-header-icons.tar.gz"
   it "exports the theme correctly" do
     package
     Dir.chdir("#{dir}") do
-      `tar -xzf discourse-header-icons-theme.tar.gz`
+      `tar -xzf discourse-header-icons.tar.gz`
-    Dir.chdir("#{dir}/discourse-header-icons-theme") do
+    Dir.chdir("#{dir}/discourse-header-icons") do
       folders = Dir.glob("**/*").reject { |f| File.file?(f) }
       expect(folders).to contain_exactly("assets", "common", "locales", "mobile")
@@ -115,7 +115,7 @@ describe ThemeStore::TgzExporter do
     exporter = ThemeStore::TgzExporter.new(theme)
     exporter.cleanup!
-    expect(filename).to end_with "/discourse-header-icons-theme.tar.gz"
+    expect(filename).to end_with "/discourse-header-icons.tar.gz"
GitHub sha: 886ba9df
