DEV: Correct theme:qunit help text (#13104)
  • Task name is themes:qunit, not themes:unit
  • Some shells try to expand the square brackets. The whole thing should be enclosed in quotes to avoid this
diff --git a/lib/tasks/themes.rake b/lib/tasks/themes.rake
index 2de8b30..83c1038 100644
--- a/lib/tasks/themes.rake
+++ b/lib/tasks/themes.rake
@@ -106,11 +106,11 @@ task "themes:qunit", :type, :value do |t, args|
     raise <<~MSG
       Wrong arguments type:#{type.inspect}, value:#{value.inspect}"
       Usage:
-        `bundle exec rake themes:unit[url,<theme_url>]`
+        `bundle exec rake "themes:qunit[url,<theme_url>]"`
         OR
-        `bundle exec rake themes:unit[name,<theme_name>]`
+        `bundle exec rake "themes:qunit[name,<theme_name>]"`
         OR
-        `bundle exec rake themes:unit[id,<theme_id>]`
+        `bundle exec rake "themes:qunit[id,<theme_id>]"`
     MSG
   ENV["THEME_#{type.upcase}"] = value.to_s
GitHub sha: bd8c2b46
This commit appears in #13104 which was approved by CvX. It was merged by davidtaylorhq.
