DEV: d-editor helper should be synchronous (#7706)
Also ensures trigger has happened before assertion and prevents leaking formatTextWithSelection into global context
diff --git a/test/javascripts/components/d-editor-test.js.es6 b/test/javascripts/components/d-editor-test.js.es6
index 612d67d..edb1a53 100644
--- a/test/javascripts/components/d-editor-test.js.es6
+++ b/test/javascripts/components/d-editor-test.js.es6
@@ -1,5 +1,6 @@
 import componentTest from "helpers/component-test";
 import { withPluginApi } from "discourse/lib/plugin-api";
+import formatTextWithSelection from "helpers/d-editor-helper";
 moduleForComponent("d-editor", { integration: true });
@@ -797,12 +798,14 @@ composerTestCase("replace-text event for composer", async function(assert) {
         .lookup("app-events:main")
         .trigger("composer:replace-text", "green", "yellow", { forceFocus: true });
-      let expect = await formatTextWithSelection(AFTER, CASE.after); // eslint-disable-line no-undef
-      let actual = await formatTextWithSelection( // eslint-disable-line no-undef
-        this.value,
-        getTextareaSelection(textarea)
-      assert.equal(actual, expect);
+      Ember.run.next(() => {
+        let expect = formatTextWithSelection(AFTER, CASE.after);
+        let actual = formatTextWithSelection(
+          this.value,
+          getTextareaSelection(textarea)
+        assert.equal(actual, expect);
diff --git a/test/javascripts/helpers/d-editor-helper.js b/test/javascripts/helpers/d-editor-helper.js
deleted file mode 100644
index 4245437..0000000
--- a/test/javascripts/helpers/d-editor-helper.js
+++ /dev/null
@@ -1,15 +0,0 @@
-Ember.Test.registerAsyncHelper("formatTextWithSelection", function(
-  app,
-  text,
-  [start, len]
-  return [
-    text.substr(0, start),
-    text.substr(start, len),
-    text.substr(start + len),
-  ].join("");
diff --git a/test/javascripts/helpers/d-editor-helper.js.es6 b/test/javascripts/helpers/d-editor-helper.js.es6
new file mode 100644
index 0000000..412409e
--- /dev/null
+++ b/test/javascripts/helpers/d-editor-helper.js.es6
@@ -0,0 +1,11 @@
+export default function formatTextWithSelection(text, [start, len]) {
+  return [
+    text.substr(0, start),
+    text.substr(start, len),
+    text.substr(start + len),
+  ].join("");
diff --git a/test/javascripts/test_helper.js b/test/javascripts/test_helper.js
index deeaf54..1fe03be 100644
--- a/test/javascripts/test_helper.js
+++ b/test/javascripts/test_helper.js
@@ -32,7 +32,6 @@
 //= require helpers/assertions
 //= require helpers/textarea-selection
 //= require helpers/select-kit-helper
-//= require helpers/d-editor-helper
 //= require helpers/qunit-helpers
 //= require_tree ./fixtures
GitHub sha: df954574
